| Cognitive_Faux |
 Cognitive_Faux Nova Slayer
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 22:06 - 10 Jan 2011 Post subject: |
You probably have fouled the plugs up which is why it stalled when you let it off choke as the revs were to low for it to idle.
The high temp will be from it not moving. Not moving = no air through rad to cool the water. I would have expected the fan to cut in though. If it didn't you still had a fair way to go before it got properly hot EDIT:or its broken
It probably was hotter than your used to as the temp of most bikes sits pretty low this time of year. Around 70 degrees or so. In the summer this will easily shoot up to 100+ so I wouldn't worry to much. Take it for a good run to clean the plugs.
Is it a digital temp gauge or an analogue one?
If it was digital what temp was it reading? Anything below 110 degrees and your safe. Anything above that and there is a serious problem somewhere!! The bike should never get that hot.
| Ingah |
 Ingah World Chat Champion
| stinkwheel |
 Posted: 22:31 - 10 Jan 2011 Post subject: |
They do get hot pretty quickly if they're not moving although as said, the fan should have been on if the temperature was in the red so that's one thing, either your fan or fan switch isn't working.
Test by disconnecting the wire from the fan switch (there is only one) and connecting it to earth with the ignition on. The fan should come on. If it does, the switch is not working. If it doesn't, the fan is not working.
Maybe worth giving the radiator a clean off? I did mine recently and its running noticeably cooler. I took the plastic gurard off, gave it a good soaking by spraying it with hot soapy water followed by cold fresh water to loosen any dirt then gave it a blow through with an airline. Blasted a fairly impressive quantity of dead flies and road grit out. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Cognitive_Faux |
 Posted: 23:53 - 10 Jan 2011 Post subject: |
thanks guys.
its an anolouge guage. and its never been accurate just like all the other guages.. epescially the fuel.
now that you mention the fan.. i cant remember it ever working.... unless its really quiet.
clean the rad off? ok.
thanks. hopefully no news is good news
 ____________________ bike theory (pass) bike test (pass)(4 minors) car theory (pass) car test (pass)(1 minor!!!)
cb125t->sr125->expressII50->xlr125->GS550L & GS550E->XBR500 'chop'->YZF600R->FZS600->GSF650->fantic 212cc->gsf650->kwak GT750->VFR750 ->
HGV class 2 (pass) |
| Ingah |
 Posted: 00:01 - 11 Jan 2011 Post subject: |
| ThunderRus wrote: | thanks guys.
Most of the time, the fan will not be working. Only really when you're sat in traffic for longer periods should you really expect it to come on (easy enough to check though, just let it sit idling for a while). It's entirely possible yours simply doesn't work and no one's ever noticed/bothered to fix it
I noticed mine doesn't always come on, tracked it down to the switch, and still haven't got round to it yet over a year later (i'm usually very on top of mechanical things), despite doing lots of city riding. ____________________ -- Ingah |
| Shaft |
 Shaft World Chat Champion
 Posted: 00:23 - 11 Jan 2011 Post subject: |
These days I fix cars, but the theory's the same.
I'm with everyone else; check the coolant, if it's low, top it up, then check the fan/thermo switch, as described elsewhere.
If you do have to top up the coolant, and you haven't had to before, check for leaks. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Cognitive_Faux |
| Cognitive_Faux |
| Cognitive_Faux |
| Shaft |
| 0l0dom0l0 |
| Vincent |
 Vincent Banned
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
