Too Lean ?
JackDaniels
PostPosted: 19:45 - 17 Jan 2011    Post subject: Too Lean ? Reply with quote
hi guys, i did a top end engine rebuild on my peugeout trekker today and want to make sure its not running lean Smile
https://i53.tinypic.com/j7cnjm.jpg
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
Paxovasa
PostPosted: 19:49 - 17 Jan 2011    Post subject: Reply with quote
Here you go:
Click me
0l0dom0l0
PostPosted: 20:06 - 17 Jan 2011    Post subject: Reply with quote
That's fine. Don't fiddle with anything.
cb1rocket
PostPosted: 22:27 - 17 Jan 2011    Post subject: Reply with quote
Paxovasa wrote:
Here you go:
Click me
Reading that link was good but then its get confusing when it says:
Why Hot and Cold Sparkplugs? Using a hotter or colder sparkplug can be just the fix to an engine problem. Very basely, if your motorcycle engine is running hot then try using a colder plug, if it is running hot try a colder plug.
Huh?!
Blue_SV650S
PostPosted: 23:05 - 17 Jan 2011    Post subject: Reply with quote
cb1rocket wrote:
Paxovasa wrote:
Here you go:
Click me
Huh?!
If you run the wrong grade plug, it can lead to pre-ignition - basically the electrode of the plug glows and ignites the fuel too early. Going for a cooler plug means it takes more heat to to get to this point. If you go too cool, then there won't be enough heat in it to burn off the soot/oil. It is a fine line between the two. Generally speaking, you would only want to change one grade - one way or the other - to get desired effect. e.g. if you were running a 9, you probably won't need more than a 10 or less than an 8 ...
It has nothing to do with mixture ...
Your plug looks fine BTW Thumbs Up
The last post was made 15 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.4 - MySQL Queries: 14 - Page Size: 44.57 Kb
