| Author |
| kneedown |
 kneedown Nova Slayer
| Back to top |
| Vincent |
 Vincent Banned
 Posted: 14:13 - 30 Jan 2011 Post subject: |
You could try posting in the"Workshop" section
Just look all round where the cylinder meets the engine cases and look for leaks. Using home made gaskets for the base of the cylinder can be a bit dodgy as they need to be the right thickness. |
| Back to top |
| Damon |
 Damon World Chat Champion
do a compression test  |
| Back to top |
| Vincent |
 Vincent Banned
| Back to top |
| Damon |
 Posted: 14:32 - 30 Jan 2011 Post subject: |
Will it not? I was under the impression any slight airleak in the base gasket would lower compression.
My mistake. As you were  |
| Back to top |
| Vincent |
 Vincent Banned
| Back to top |
| Damon |
 Posted: 14:37 - 30 Jan 2011 Post subject: |
Of course. I'm being a bit thick
It's all this sitting at work malarkey making me crazy  |
| Back to top |
| iooi |
 iooi Super Spammer
 Posted: 15:06 - 30 Jan 2011 Post subject: |
I assume you mean leaking cooling fluid.
Two options either you sump oil will turn really milky as the coolant leaks in there, or you will see wet patches round the outside of the cylinder.
Oh and the coolant level will drop in the radiator/expansion tank ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Back to top |
| Vincent |
 Vincent Banned
| Back to top |
| stinkwheel |
 Posted: 17:07 - 30 Jan 2011 Post subject: |
The base gasket seals between the crankcase and the outside world.
If it was leaking, you'd see runny black petrol/oil mixture oozing round the join between the barrel and the cankcase. If the join is clean, it's not leaking. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| kneedown |
| Back to top |
| kneedown |
| Back to top |
| stinkwheel |
 Posted: 21:41 - 30 Jan 2011 Post subject: |
One thing that always used to be recommended and you don't hear so much these days is to re-torque the cylinder head nuts at 5, 50 and 500 miles post fitting. Gaskets squash and heads settle after a few heat cycles which can leave them loose.
I just did the ones on my Enfield. They were done up to 24ft/lb when I fitted the head. Five (probably nearer 10 the truth be told) miles later, I went to torque them up (in two stages, 15ft/lb then 24ft/lb). Two of them took a bit of a turn to get them up to 15. All of them needed tightening to 24.
A slight pain in the backside taking the tank and rocker covers off having only recently put them back on again but it definately needed doing.
It may be an older bike design, but the gaskets are made of exactly the same stuff as a modern bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
The last post was made 15 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
