What can I do to close this gap in the exhaust?
everyreasonto
PostPosted: 18:53 - 03 Feb 2011    Post subject: What can I do to close this gap in the exhaust? Reply with quote
Just bought this exhaust and downpipes:
https://i953.photobucket.com/albums/ae14/everyreasont/03022011258.jpg
But when I have fitted the two parts together I have small air gaps around two of the bolt holes like below:
https://i953.photobucket.com/albums/ae14/everyreasont/03022011257.jpg
What can I do to get rid of these gaps? I was thinkinging washers underneath at first but then I realised that would create a gap the thickness of the washer all the way around.
Also, should I use exhaust paste between downpipe, end can and adapter?
Ta
Dazbo666
PostPosted: 19:01 - 03 Feb 2011    Post subject: Reply with quote
In the past I've used either a small blob of exhaust paste or an asbestos washer, with a metal washer over the top to hold it in place
Word of the day : DILLIGAF
fiery tupp
PostPosted: 19:05 - 03 Feb 2011    Post subject: Reply with quote
There shouldn't be a gap, if you use the washers directly under the stud head ? Neutral
If you can't fix it with a hammer , use your head .
Ichy
A washer underneath the allen bolt.
Use firegum to assemble it all together. It works as a lube when your fitting it together then it expands when heated filling any gaps that may be there. No problem at all to take apart afterwards.
everyreasonto
PostPosted: 22:29 - 03 Feb 2011    Post subject: Reply with quote
Cheers fellas, can't wait to hear this beast when I finally get it fitted!
Dazbo666
PostPosted: 23:00 - 03 Feb 2011    Post subject: Reply with quote
I have the stubby stainless version of that can fitted to the Bandit - and it's one fantastic throaty, deep sound compared to the OEM
The last post was made 15 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.07 - MySQL Queries: 14 - Page Size: 48.72 Kb
