xr250 rear brake sticking
eddclarke
PostPosted: 20:04 - 08 Feb 2011    Post subject: xr250 rear brake sticking Reply with quote
Hey
What can cause a rear brake to start sticking? It got to the point where the disc was glowing red!!!
I have only just fitted a new master cylinder, could this be the cause?
Ed
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
Blue_SV650S
PostPosted: 20:38 - 08 Feb 2011    Post subject: Reply with quote
Sticky piston, sticky slider pins ... a stone jammed in ... a partridge in a pear tree?
robocog
PostPosted: 21:32 - 08 Feb 2011    Post subject: Reply with quote
Assuming they work on the same principal to car master cyls it could be a case of over adjustment on the M/Cyl
They do need a bit of "free play" or slop when the brake pedal/lever is fully released, otherwise the fluid cannot return back fully
What happens in use when someone has over enthusiastically adjusted the "slop"... the pads heat up, which heats the fluid a bit, it expands and instead of making it back to the reservoir it can only put the brake on harder, which heats the fluid even more, causing it to lock eventually (and sometimes quite spectaculalry)
easy to test by trying to retract the pads and pistons by hand...cannot be done?
slacken the master cylinder pushrod right off or disconnect the pedal from it completely (whichever is easiest) and try again
If it still fails time for a stripdown of the calliper
(either way make sure you have something ready to keep the overflow of fluid from spilling out of the reservoir - its nasty stuff and makes a mess of paint/some rubbers/some plastics)
Regards
Rob
Needs a bigger garage...
The last post was made 15 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.6 - MySQL Queries: 14 - Page Size: 35.86 Kb
