| badj |
 badj Derestricted Danger
| Kickstart |
 Kickstart The Oracle
| badj |
| Kickstart |
 Posted: 18:48 - 13 May 2011 Post subject: |
It isn't in series. If you check the red / orange wire it splits so it goes to the regulator / rectifier, part 22 (presume voltmeter on the clocks) and importantly number 18 which is the ignition switch. With the ignition on this will supply power to the green and orange wire that goes to the regulator / rectifier and which also supplies power to the 7.5 amp and 15 amp fuses.
Basically the red / orange wire from the regulator rectifier feeds the battery and the bikes electrics, while the one from the battery via the 20a fuse feeds the electrics. If the battery is flat the excess from the regulator / rectifier after powering the bike will charge the battery, while if the regulator / rectifier is dead (or the engine just not running) then the battery will supply power to the bike.
With the ignition off the 7.5a and 15a fuses should have no power at all (no voltage between them and earth). With the ignition on but the engine not running you should get battery voltage between them and earth. With the engine running you should get voltage which will vary with revs but will be maintained by the battery.
Not sure the current readings at the fuses matter for this. They will merely let you know how much power is being drawn on that circuit (or pop the multimeter if you are unluck ).
| badj |
| Kickstart |
 Posted: 19:04 - 13 May 2011 Post subject: |
It shouldn't be earthing things out like that. If it did normally it would just flatten your battery when parked (as the battery positive would feed straight through it to earth).
My main guess would be a dead regulator / rectifier, but it seems unlikely you would have 2 dead in the same way. I am not sure how the units are wired up internally, but if there is a connection (ie, direct connection rather than an induced current) to the AC side then a short on the generator side could provide a path to earth.
| badj |
| badj |
 Posted: 21:06 - 13 May 2011 Post subject: |
Update:
Reg/Rec disconnected...
Generator disconnected...
CDI disconnected..
absolutely no shorts in the loom or bare wires..
Measured between the + terminal and the output of 20A fuse (which should be +12v, so technically in the pic, nothing)
https://imageshack.us/m/190/5641/imag0807e.jpg |
| Kickstart |
| badj |
| Kickstart |
 Posted: 22:18 - 13 May 2011 Post subject: |
I can't see what you are measuring, and reading your previous reply you say it should be +12v, when it clearly shouldn't be. I take it you mean that both sides of the fuse should be +12v (assuming the fuse is in place) so no difference and so no voltage between them.
If the output from the fuse is earthed then you would get 12V (but probably also an instantly blown fuse or smoking wiring if the fuse was all that went between the battery +ve and -ve terminals) between it and the positive terminal .
If the fuse -ve terminal is earthed then there is something that has broken and shorted to earth. I would suggest the first thing to try is to disconnect the ignition switch to determine which side of the ignition switch the short is.
The wire should be pretty much direct from the battery +ve to the 20a fuse. I would also check for continuity between the battery +ve leads and the fuse holder (disconnect the battery to ensure that you do not get any odd readings).
| badj |
| badj |
| badj |
| badj |
| Kickstart |
| badj |
| Kickstart |
The last post was made 15 years, 132 days ago. Instead of replying here, would creating a new thread be more useful? |
