Problem solving tips needed to screw in battery screws
Shay HTFC
PostPosted: 14:04 - 04 Mar 2011    Post subject: Problem solving tips needed to screw in battery screws Reply with quote
The terminals on my new battery are designed so that you screw in horizontally from the side, but the contacts on my bike are designed to be screwed in from the top.
I have tried manoeuvring the contacts, but there isn't space for the wire to fit in sideways.
Has anyone had this problem before and what did they do?
I figure I can bend the contact metal, but I don't want it to snap (+ its fecking solid!).
I was also looking at getting a right angled bracket (along the lines of bracket ), but I'm sure there is a better way.
So what would you do?
(I've stuck a little image in to give an idea of the problem)
Full Motorbike License - GS500E '95
andys675
PostPosted: 14:28 - 04 Mar 2011    Post subject: Reply with quote
you can get right angle convertors, usually get a pair in a YB12AL-A2 battery as they fit 535 virago and 3HE FZR600 and the angles are different for each bike
most bike shops should be able to get you one
PostPosted: 14:29 - 04 Mar 2011    Post subject: Reply with quote
I would just bend it to fit. Those brass tabs are stronger than the look. Don't bend it back & forth too many times though because it will work-harden and snap very quickly.
The last post was made 15 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 14 - Page Size: 36.18 Kb
