Clutch issue
total_uk
PostPosted: 18:15 - 12 Mar 2011    Post subject: Clutch issue Reply with quote
I've just bought a 99 reg CBR600F. To get the biting point on the clutch I have to nearly release the lever all the way out before it bites. Does this mean the clutch is near needing to be replaced or just the way the clutch is set?
Thanks
MinhDinh
PostPosted: 18:18 - 12 Mar 2011    Post subject: Reply with quote
Have you tried adjusting the screw?
Hit the G spot. Wink
total_uk
PostPosted: 18:21 - 12 Mar 2011    Post subject: Reply with quote
I haven't yet, but will have a go to see if that changes things. thanks.
MinhDinh
PostPosted: 18:27 - 12 Mar 2011    Post subject: Reply with quote
My RS use to get loose a little bit every so often since I had to use the clutch quite a bit. A little tweak and it got closer to the handlebars.
If the bike starts slipping then that's another issue.
The last post was made 14 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.02 - MySQL Queries: 14 - Page Size: 40 Kb
