| Tristan. |
 Tristan. World Chat Champion
 Posted: 13:28 - 12 Mar 2011 Post subject: Estimating workshop fabrication costs. |
This is for a uni group design project. One of the last bits to do is the manufacturing costs section. Basically I'm trying to estimate the costs to produce this:
https://i54.tinypic.com/2v0oaxy.jpg
(all made from 40 x 40 mm box 3mm thick mild steel)
And I need one key value, for it all to come into place. how long it would take to weld together. The whole things made from 40mm box section, in 3 big bolt together sub assemblies. Theres essentially there's 457 welds on it, roughly halved between 40mm T joint fillet and 40mm butt joint welds. plus 8 1000mm lap joint fillets. Mig or arc would be suitable, and the choice will depend on comparing the costs of each. Though if I can only get data for one kind It doesn't matter.
Obviously with it being third year coursework I can hardly cite some bloke off BCF telling me they'd take x seconds each. (though that kind of approximation would be helpfull, so I can do some fag packet maths to get an idea) so what I really need to know is if there's some kind of industry standard or rule of thumb I can look up, or something along those lines. Even a theoretical capability stated on welders would be a better startpoint. Overheads, wages, costs of employment, time to mount and prep etc I'm all capable of sorting. I just need this one value, and an actual source to cite.
Cheers for any help |
| fredsredhat |
 fredsredhat Traffic Copper
| Tristan. |
| ZRX61 |
 ZRX61 Victor Meldrew
| ZRX61 |
| Tristan. |
| ZRX61 |
| Tristan. |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 10:57 - 18 Mar 2011 Post subject: |
at a random stab in the dark i'd say there was about 25hrs in that
so 1000quid labour + materials,
is there no one in the college who can do the welding?? do they not have a welding/fabrication course running at the school??
i personally think your hub steering axles are up to the job looking at the pic ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Blackwolf |
 Blackwolf Burgerfist
| ZRX61 |
| kestrel |
 kestrel Nearly there...
 Posted: 22:07 - 18 Mar 2011 Post subject: |
Tristan.
It's difficult to estimate an accurate fabrication time on something like this without a bit more detail. A one off job like this takes a considerable amount of time, making large numbers on a production run would work out *MUCH* quicker per unit.
As a rough guide, we use circular TCT pull down saws, a square cut in 40x40x3 RHS takes about 10 seconds. The only practical welding process for this type of work is MIG, again as a guide, a 'Tee' joint, incorporating two fillets and two butts would take less than a minute.
Each member of this structure will require the saw to be set up for length and cut angles, so for a one off you must factor in the set up time plus the actual cut time, on a production run of 10 units the additional 9 pieces are cut time only.
One of the most time consuming aspects of any fabrication is setting up the various components relative to each other. This is where jigs are usefull. A jig removes this set up time, it doesn't need to be complicated but it does need to hold the components in their correct position and at the same time leave access to the weld joints. A quick glance at your structure suggests that you could actually fabricate it in sub assemblies using smaller jigs. Once you have made your various jigs you can cut and prep all of your material for however many units you require, assembly is then just a case of loading the various members into the jig and welding.
Charging out rates vary considerably, the fab shop I work in charges £30 per hour. |
| Tristan. |
 Posted: 23:17 - 18 Mar 2011 Post subject: |
Very helpful thanks.
I left a key point out of the OP. It's theoretical costs for producing it in house, not contracting it out. (Though when the in house time is found then working out a contract price at £30/hour is easy enough to compare)
There is a fab lab in uni, but with it coming up to dissertation deadline there's no time to get the technicians to do a few runs. I got them to give me some 40mm box though, so I can cut clamp and weld it at home. I'm shit at welding so thats not much use, but I can take it with me round local fab shops to say "how long would it take you to do this?"
Kestral, thats very helpful. Couple of questions
I'm working on the assumption of about £12/hr for the welder. For the bloke who does the cutting, clamping, prepping etc, any idea what sor of wage he'd be on?
I've only welded rusty crap on a farm, or as a hobby. I've never welded any new metal. How much prep does metal fresh from the rollers take?
I've counted the cuts that it'll take. And I've treated right angled cuts different to other ones. How much longer do you reckon to dial in an angle on a saw? (though as you say with batch and queue that's several extra processes per assembly)
Also, I've just done the startup costs today, from memory I think I've considered a pull down saw, pillar drill, mig setup, grinder, welding mask, apron and gauntlets, bandsaw, extraction system, fire extinguisher , compressor, gun and respirator and some PPE, Anything else ubitquous to a shop floor? |
| kestrel |
 Posted: 00:30 - 19 Mar 2011 Post subject: |
| Tristan. wrote: | Very helpful thanks.
Tristan.
Fab shop time is a bit of a variable, there are shops around that turn out quality work in the low £20's and up into the £40's. As I said before our charging out rate is £30 per hr for general fabrication, we also specialise in high integrity pipework which is charged at a considerably higher rate. As for the guy on the shop floor, rates at a guess are anywhere between £7.50 and £14.00 per hr.
Hot rolled materials require very little prep before working, box sections however usually have an oily film on them to give a little weather protection in the stock yard, we usually degrease them before use with paraffin which makes them cleaner to work with and easier to mark.
Dialling in an angle cut on a pull down saw is relatively quick, most have an engraved angle ring which is pretty accurate on a quality machine.
Where startup costs are concerned, if you are going to make your living with tools then you should always buy the best you can afford, downtime on a machine costs money. Sadly one of the down sides of the current recession is an abundance of used professional quality engineering tools which can be bought very cheaply. Perhaps the most often used tools in a fab shop are the saw, drill and welder, they all need to be good quality workhorses.
The next most important item in any fab shop is a good sturdy steel bench, again don't skimp on this. A fabrication bench should be as large as you can accomodate and be accessable from all four sides, have a good thick steel top and be built absolutely flat and level. The reason for having a flat level bench is that if you are fabricating on the bench then the bench top is your datum face from which you can reference squares and levels. Jigging a single plane frame can be as simple as tacking a few stops to the bench top.
I've been reading your thread on the CAD bike. CAD drawings are extremely usefull particularly if each member of a structure is detailed seperately giving lengths and cut angles which can be set up directly on saw stops and drill stops. |
| ZRX61 |
 Posted: 18:23 - 19 Mar 2011 Post subject: |
It's just occurred to me that I may know the lecturer, whats his name?  ____________________ They're not one night stands, they're auditions. |
| warped one |
 warped one Banned
The last post was made 15 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
