marcusbandit |
marcusbandit Derestricted Danger
Posted: 16:47 - 24 Mar 2011 Post subject: Bandit 600 Rev Problem |
Hi all, I got a problem with a bandit i purchased about 4months ago , its a 03 600s Faired version. It has been sitting in someone's back garden for about 4years with a full fuel tank... (5000) miles on it. I collected it payed for it , payed a mechanic to strip all fuel system side carbs tank etc fully clean it out rebalance carbs adjust mixture screws, set clearance valves all new inline filters new fuel tap. Now its up and running but it has a "little" problem when riding the bike or sitting in a garage, when i rev past a quarter turn of the throttle it coughs and seems to lose power, it picks up revs really really slow , as soon as it hits 5k revs it stops coughing power kicks in and it goes like anything but before 5k it just fails in any gear at any speed. Things ive done to try to fix this , New CDI unit , new TPS , new sparkplugs , check coilpacks/Ht leads , set Tps correctly taken carbs off again and recleaned , new air filter checked for airleaks checked for any kinked hoses you name it ivied tried it ive run out of options.. help! |
Paxovasa |
Paxovasa World Chat Champion
marcusbandit |
marcusbandit |
Paxovasa |
marcusbandit |
Paxovasa |
Posted: 17:36 - 24 Mar 2011 Post subject: |
Take the air filter out, start the bike, let it warm up and then try revving it.
Report back with the results. ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
0l0dom0l0 |
0l0dom0l0 World Chat Champion
marcusbandit |
0l0dom0l0 |
Posted: 19:18 - 24 Mar 2011 Post subject: |
Sorry I ged your pardon, I thought you had changed the air filters for pod ones. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
Paxovasa |
Ditto |
Ditto Nearly there...
marcusbandit |
Paxovasa |
Posted: 11:59 - 25 Mar 2011 Post subject: |
Yeah, does sound like it is running lean.
Turn the mixture screw in all the way, count the number of turns it takes.
Then undo it 2.5 turns, then try the bike. It may need slight adjustment, but only adjust it .25 of a turn at a time.
If you are unsure about doing the work, you could get it dyno tested. ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
marcusbandit |
Paxovasa |
marcusbandit |
Posted: 12:57 - 25 Mar 2011 Post subject: |
Yes hot engine not nice but i kept clear the best i could i wound the screws in all the way i didn't over tighten them im a mechanical fitter by trade so im not totally useless just part i wound them off to 1 and 3/4 turns , did'nt make a different tried another 1/4 got better and better , im on 3full turns on each carb and its running 90% better would help if i had a stubby flat head il grab one from work was using a rachet.... so il redo them after work but im pretty sure the mixture screws was causing the problems, but 3 turns??? surely it should'nt need this many should it? |
Paxovasa |
Ditto |
marcusbandit |
marcusbandit |
marcusbandit |
marcusbandit |
ortigas |
ortigas L Plate Warrior
Posted: 00:40 - 03 Jun 2011 Post subject: |
Im having the exact same problem, with the exact same bike.
I've taken out the carbs to clean, cuz i thought it was cloged jets (but its was very clean inside, i still cleaned it tho), and after puting everything back together the bike was runing like new, its been a week and today after work on the way back home, i push it too far i guess, after a nice drag i let off the throttle and when the bike was desaccelerating it missfired (nothing too harsh but not usual) i got back on throttle and teh damm problem was back-.-
on teh carbs tops there are diafragms with a spring, in one of them i have like a small piece of metal that looks like its there to avoid the diafragm to streach to high, but in the other 3 theres no such thing, maybe its one of the needles that came out of the hole when missfired? |
ortigas |
Posted: 18:43 - 03 Jun 2011 Post subject: |
Sorry for the bumping but marcus did u got ur bandit fixed?
for anyone else reading care to give a hint please ? |
The last post was made 12 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
