| SpannerMonkey |
 SpannerMonkey World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 21:23 - 07 Apr 2011 Post subject: |
chuck the cheapest oil in you can find, 30/40 may be,
i don't know if you can even buy that any more
basically you want an oil with a low second number, the lower the number the thicker the oil
eg 0w/50 is thick on start up (to build up oil pressure quickly) but gets really thin when warm ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| SpannerMonkey |
| weasley |
 weasley World Chat Champion
| SpannerMonkey |
| Noxious89123 |
 Noxious89123 World Chat Champion
| jimspeed |
 jimspeed World Chat Champion
| stinkwheel |
 Posted: 22:26 - 07 Apr 2011 Post subject: |
As I recall (and this is pretty dimly mind, it's been a long time since I guddled in one of those engines), there is an oil filter, and a very good one. It's just not what you'd think of as an oil filter in the traditional sense.
It's a centrefugal filter. The oil passes through the rotating part of the clutch assembly. As it does so, it gets flung to the outside of a metal plate which is aprt of said clutch assembly. There are a series of notches round the edge of this plate which trap any particulate matter in the form of sludge. Once in a blue moon, you take the engine cover off and scrape the sludge out with an old screwdriver.
I think there is also a basic gauze type filter on the oil pump pickup which is worth giving a clean if you're in there.
As such, detergents are actually a good thing because they help keep any muck suspended in the oil which the filter can then catch rather than sludging it in the sump. Other additives may or may not be a good thing depending on their effect on the clutch.
Pretty sure I used to use 20w-50 in mine but it's possible they were designed to run on either straight 30w or 50w oil initially, you'd meed to check a manual. This doesn't mean that is what's best, it's just what was available at the time. Multigrade oil is almost certainly better.
Ring blowpast shouldn't be an issue, the Japs build tight engines and always did. That motor should have two piston rings, a three piece oil control ring and I can confirm they have very tight valve guides with seals on. If you're getting blowpast, it needs new rings or a rebore.
Where exactly is this oil leak? I don't recall there being a gasket at the crankcase join, it's metal to metal.
EDIT: I wonder if your crankcase breather is blocked. You have many of the symptoms. ie down on power, burning oil, oil leaks from the crankcase. I honestly can't remember where the breather is on these, it's probably just a small hole in the top of the crankcase somewhere. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| SpannerMonkey |
The last post was made 15 years, 203 days ago. Instead of replying here, would creating a new thread be more useful? |
