How and When to post Bug Reports
Bike Chat Forums Index -> Forum Feedback & Help
Korn
Admin
PostPosted: 11:29 - 20 Jan 2004    Post subject: How and When to post Bug Reports Reply with quote
Please post detailed information!
Most problems will require you to state your OS & Browser version (find out here if you don't know), and in the case of network problems it would be useful to know the IP address you had when you experienced the problem initially (again, find out here if you don't know it). If you tried clearing cache/cookies to fix the problem, please state that you did this and if it worked or not.
Common browser problems
Broken images, disappearing stylesheets and weird graphical bugs are usually solved by clearing your browser cache and restarting your browser. Try this before reporting a bug, otherwise I'll just end up telling you to try it anyway. It's also super helpful if you could try a different browser, to see if the problem persists.
The topic reporting my bug is locked, what do I do?
Any topic reporting a bug in this forum that is considered fixed is then closed. If you continue to experience the problem, you'll need to start a new thread as it's likely to be a different issue causing the same problem and will need a separate solution.
3516 Miles, 11 Countries
Post new topic   Reply to topic    Bike Chat Forums Index -> Forum Feedback & Help All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 28.24 Kb
