Getting fcuked off now...
GREENI3
PostPosted: 21:40 - 27 Apr 2011    Post subject: Getting fcuked off now... Reply with quote
Another thing to add to my list of things going wrong with the ped.
Whilst I was out on a ride on Monday, my ay50 suddenly lost all power and came to a stop.
Wouldn't start after kicking it a few times, so had to push it to the nearest petrol station.
Turns out the spark plug cap came off, so I put it back on, kick started it and it started up. But this time it wouldn't idle and would conk out after about 2 seconds without applying any revs.
And now my headlight and the lights behind the speedo and fuel gauge aren't working either. But the warning light for the indicators is?
Checked the battery e.t.c and all is as it should be.
Right before it broke down, the horn gave a weak little whine.(almost like it was dying)
Anyone got any ideas on how to fix it?
I've bought another spark plug which should arrive tomorrow.
Just annoying because the spark plug is in such an awkward place and can't get a socket round it. Mad
Cheers Thumbs Up
Ed Case
PostPosted: 21:48 - 27 Apr 2011    Post subject: Reply with quote
DONT be ham-fisted tightening up the spark plug, it's a p of p to strip the thread, a lot easier than you might think !.
Livefast123
PostPosted: 21:53 - 27 Apr 2011    Post subject: Reply with quote
Sounds like the start of an annoying electrical problem Thumbs Down
For starters have you make sure that the battery is charged and holding that charge
Current ride - Yamaha MT-07
GREENI3
PostPosted: 21:58 - 27 Apr 2011    Post subject: Reply with quote
Yep, happily holds 12.6v.
Livefast123
PostPosted: 22:10 - 27 Apr 2011    Post subject: Reply with quote
Have you checked the fuses on the bike, can't remember where they are if if it has any as I had my Katana 11 years ago Neutral
When the plug cap came of it could have created a voltage spike which blew the bulbs.......may be worth trying a new headlight bulb to discount this. Also may have damage voltage regulator / rectifyer.
GREENI3
PostPosted: 22:16 - 27 Apr 2011    Post subject: Reply with quote
The fuse was fine. Not split or anything.
All the indicators, horn, warning lights and brake light work so can't see why it would just be the headlight and instrument pannel lights that aren't working?
Truzo
PostPosted: 23:12 - 27 Apr 2011    Post subject: Reply with quote
Dodgy Connectors
Current Bikes: RXS 100, RD 125lc3, RD 350 F2
stonesie
PostPosted: 23:29 - 27 Apr 2011    Post subject: Reply with quote
"can't see why it would just be the headlight and instrument pannel lights that aren't working?"
Sounds like all the lights that were on when your plug cap fell off, it is worth taking the bulbs out to check them.
I had a random one the last time I took the CG out, it blew both eliments in the stop/tail bulb while I was checking it over, changed the bulb and it was fine.
iooi
PostPosted: 05:27 - 28 Apr 2011    Post subject: Reply with quote
Check all the wiring along the frame. Something has come apart or connecters have broken.
While the battery may show 12V, what does it show with the engine running.
Glenben92
PostPosted: 06:29 - 28 Apr 2011    Post subject: Reply with quote
You should really replace the plug cap with a decent one, it's always recommended. It caused me problems for ages since it can be such an awkward problem to find. I only fixed it a few weeks before selling the ped, bastard who bought it had a reliable little bike thanks to my pain!
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
GREENI3
PostPosted: 12:56 - 28 Apr 2011    Post subject: Reply with quote
The bulb thats currently in the headlight is a 60/55w.
But in the haynes manual it says the headlight bulb should be a 35/35w.
Did the headlight stop working because the bulbs wattage is too high?
Livefast123
PostPosted: 13:39 - 28 Apr 2011    Post subject: Reply with quote
No but it may have melted the wiring due to it's higher current draw. Just get a new bulb, it will cost you a couple of quid then you can see whether thats the problem and if not you've got a spare which you really should carry anyway.
The last post was made 14 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.46 - MySQL Queries: 14 - Page Size: 71.37 Kb
