Speedfight 2 AC - Tuning and Advice Needed
Sleazy
PostPosted: 01:21 - 30 Apr 2011    Post subject: Speedfight 2 AC - Tuning and Advice Needed Reply with quote
Hello everyone. I've got a Speedfight 2 AC and in about one month i'll be having the whole budget to tune it up. So basically after lots of searching i've found most of the parts that i want to buy, hence i'll post them here and i want you guys to give me some advice or tell me if i've done any wrong choices...i'll be giving links (not sure if it's allowed). So, here goes:
Cylinder: Cylinder Kit 70cc Malossi Sport
https://www.scooter-attack.com/shop/#!/en/Peugeot/Speedfight-2-50-AC-EURO-2-as-from-2004/Cylinders/70cc-Sport/M317133-Cylinder-Kit-70cc-Malossi-Sport.html
Variator: Multivar Malossi
https://www.scooter-attack.com/shop/#!/en/Peugeot/Speedfight-2-50-AC-EURO-2-as-from-2004/Variators/Sport/M518752--Multivar-Malossi.html
Drive Belt: Malossi X-Kevlar Belt
https://www.scooter-attack.com/shop/#!/en/Peugeot/Speedfight-2-50-AC-EURO-2-as-from-2004/Variators/Drive-Belts-Midrace/M6112735-Malossi-X-Kevlar-Belt.html
Variator Weights: HAT Malossi
https://www.scooter-attack.com/shop/#!/en/Peugeot/Speedfight-2-50-AC-EURO-2-as-from-2004/Variators/Variator-Weights/AGEWMALOSSI-Set-of-rollers-HAT-Malossi.html
Exhaust: Giannelli Next
Already fitted.
Carb: Dell'Orto Carb 17.5mm
https://www.scooter-attack.com/shop/#!/en/Peugeot/Speedfight-2-50-AC-EURO-2-as-from-2004/Carburettors/Replacement-Sport/LDEL1403-Carburettor-17-5-mm.html
As far as the carb is concerned it clearly states that i need the mounting kit in order to fit the Dell'Orto 17.5mm...I guess that kit is this one: https://www.scooter-attack.com/shop/#!/en/Peugeot/Speedfight-2-50-AC-EURO-2-as-from-2004/Carburettors/Accessories/MF1630500-Mounting-kit-for-Dellorto-carbs.html
Someone correct me if i'm wrong about the mounting kit.
Also any advice or thoughts are more than welcome. Especially from people in this forum that have much more experience than me in such matters. I'll be waiting for responces to if my choices are good or not.
Thanks in advance, Sleazy.
connornrg
PostPosted: 04:50 - 30 Apr 2011    Post subject: Reply with quote
Add a gear up kit, they speedshites are grossly undergeared, why a bigger carb? Stock will run that setup
HTH =)
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
benandthe
PostPosted: 04:51 - 30 Apr 2011    Post subject: Reply with quote
Hi, at least I'm not the only one into tuning mopeds!!
Hmmm, where to start...
I've helped many people tune their shitfight, I mean Speedfight 2's, some last, some dont.
A rule I've always told everyone:
PICK TWO OUT OF THESE THREE:
Arrow FAST
Arrow RELIABLE
Arrow CHEAP
e.g. You want fast and reliable? It won't be cheap; You want fast and cheap? It won't be reliable.
Starting with the parts, if possible, try and stick with same manufacturer, just makes stuff easier.
Parts:
70cc Kit:
Arrow The Malossi MHR Replica - Fast and reliable, made from ally, average price around £250 (sorry, cant find a link to it, it's 5am, I'm tired...)
Arrow The Polini kit - Not as fast but made from cast iron, more reliable, about £100.
Variator:
Arrow The Malossi multivar includes (normally): variator, rollers, slider, slider guides, clutch torsion spring and new belt. Rough price is about £60 ish.
Or
Arrow The Polini kit Includes: 2 clutch springs, 2 sets of rollers, variator, variator slider and guides and new belt. price: £70.08.
Exhaust:
I dont really trust Giannelli to be honest, too many problems with them with too many friends.
If you want a nice sounding and good looking exhaust, best few options:
ArrowThe Leo Vince ZX I run this exhaust on my ped at the moment, has a nice sound, not too expensive at £121.00
ArrowThe Yasuni R Nice looking exhaust, not too loud, E marked for the countries that need it, like for the MOT here in the UK, average price £150.
Both the above exhausts are 50cc/70cc pipes and will run on either barrels.
Carb:
As standard, you will have a 12.5mm carb, so not a bad choice.
Rather than that mounting kit, just replace the inlet, rather than forcing it through a larger pipe into a smaller pipe.
A good carb that I've never had issues with,
ArrowThe YSN 17.5mm carb. Price of £46.00
Which can be used with any of these inlets:
ArrowThe Doppler Inlet, Just straight swap, no gaskets and standard reed block still used. Price of £19.00
ArrowThe Enki Inlet, Comes with new reed block and gaskets. Bargin at £25.
Next up,
Clutch and Clutch Bell:
There is a variety of different makes and models to chose from,
I prefer:
ArrowThe Stage 6 Clutch as you can remove and change clutch springs without having to remove the clutch bell and clutch everytime. Price is around £65-70.
or you have:
ArrowThe TNT clutch and clutch bell assembly. Fairly average piece of kit, will help with acceleration, but not that much really, just makes it smoother. current price: £48.00
Last but not least for now (it's been 45 mins since I started this, I need sleep!):
Gear-up kits:
By the time you have the above parts on and running, you will soon be maxing out on the gearing and not being able to go much faster, so you will need a gear-up kit.
ArrowThe Top Racing primary gear-up kit. Already pre-pressed, ready to go straight in the ped, price of only £43.00.
I can help you with most parts, but for now, I'm going to sleep!!
Post a reply and I'll let you know what I can do.
Thumbs Up Very Happy
Hope this helps a bit!
Ben.
Sold: NRG 50cc, SR125cc, CBR125cc, Mito MK 1 125cc, Speedfight 50cc, Stomp 125cc, cbr125cc, NRG 172cc, CBF 125cc, Zip 70cc, stomp 140cc
Current: CB500 (waiting on DAS)
iooi
PostPosted: 06:57 - 30 Apr 2011    Post subject: Reply with quote
Got to assume that you are over 17 if in the Uk due to the larger cc kit.
But why not simply swop to a larger ped if you want more bang for buck...
200 euro + yours will be a good start to something that will be more reliable.
Sleazy
PostPosted: 08:29 - 30 Apr 2011    Post subject: Reply with quote
Hello Ben,
And thanks for taking the time to reply to my thread with such thoroughness and also despite your lack of sleep.
First off, a correction. I've got the Giannelli Extra not the Next.
Next on to the parts..I thought that by going Malossi on most of the parts, as they are quite well known for their reliability. My SF2 does 75km/h at it's best, and around 90km/h downhill. The reason i'm tuning it is because i'm moving to a higher ground city that has more hills and inclines. So basically i wanna be doing a safe 60km/h or so while going uphill. As far as your question is concerned, i'd prefer fast and reliable. My budget is about 400-450euros though. I don't know if that's cheap or not though.
When it comes to the 70cc kit, the malossi one that i linked is a cast iron too just like the polini one you linked. I've heard that the cast iron ones are better, that's why i picked this one and not the MHR Replica.
Thanks again Ben and any more advice would be greatly appreciated.
I live in Greece mate and i'm already 22 so i don't think i'll have any problems with the law. Also i would spend more money on getting a licence for driving plus getting a 125cc or higher, than tuning the scooter, hence my option to tune it Smile
benandthe
PostPosted: 09:33 - 30 Apr 2011    Post subject: Reply with quote
Hi Sleazy,
I never said that you had the Giannelli Next or Extra, I was just saying that I don't like the exhaust's in general. Smile
I thought that you wanted to tune it for the most speed possible, but if you want it to be able to do at least 60kph everywhere then I'll provide you with my current set-up for my Piaggio which is doing just over 75mph (about 120kph) on GPS.
Arrow Polini Cast Iron 70cc kit,
Arrow Leo Vince ZX chrome exhaust,
Arrow 21mm Carb (you would be fine with a 17.5mm carb, my standard carb size is 16.5mm),
Arrow Stage 6 V Force 3 Reed block, For your speedfight you can only buy something similar to This.
Keeping the standard carb and simply buying bigger jets (those should be about right with a 70cc kit) and an uprated air filter.
I can't stress enough how important it is to run in your 70cc kit properly, if you don't you will seize it or break something within a matter of weeks or even days!
And make sure that you turn the oil pump screw out (anti-clockwise) to allow a bit more oil into the engine.
Not including a new carb, the above parts should get any speedfight 2 up to about 55-60mph (again, around 100kph+), even up a hill I can still travel at 60mph ish (96kph).
The above parts cost roughly 290 Euro all together.
Arrow Cast Iron 70cc kit is stronger, but slower, than an Ally kit.
Arrow Standard Airbox works (most of the time) better than a open air filter.
Arrow Standard carb is better most of the time, just up-jet and adjust air-fuel mix screw.
Always check your spark plug, after changing to a 70cc kit buy a new spark plug check it once every 3 days and make sure it's a nice brown colour:
Spark plug colour guide.
If anything I would say that Polini are now offering as good parts as Malossi but at a better price. over the last few years I've seen their quality improve and their parts range massively increase.
It's up to you who you buy your products from though.
All the best,
Ben.
iooi
PostPosted: 20:58 - 30 Apr 2011    Post subject: Reply with quote
Fair do's then Thumbs Up
Truzo
PostPosted: 01:05 - 01 May 2011    Post subject: Reply with quote
You will need cylinder, piston, rings, bearings, conrod, exhaust, carb, rollers and kevlar belt minimum.
It will be a pain to set up properly and it WILL blow up.
My brother had a DNA with a 70cc kit and all of the above and it blew up.
I had a Derbi Senda with a 70cc kit and guess what ?! It blew up !
Sell it and get a 125 scooter.
Current Bikes: RXS 100, RD 125lc3, RD 350 F2
Teflon-Mike
tl;dr
PostPosted: 01:50 - 01 May 2011    Post subject: Reply with quote
If you increase capacity or performance above those permitted for a moped, under C&U rules, it needs submitting for VOSA inspection to be re-registered as a motorcycle.......... have you costed that into the budget?
benandthe
PostPosted: 02:48 - 01 May 2011    Post subject: Reply with quote
He lives in Greece, don't think VOSA will care, lol.
Not true, if it's looked after then it will last ages, I ran a 70cc kit on my old moped 6 years ago, the lad that has it now is still using it!!
The hardest and most annoying thing to do will be the jetting of a new carb, hence why I said leave it.
I've been running a Polini cast iron 70cc air-cooled barrel with Leo Vince ZX exhaust, 35g in total on the rollers, .75x6mm jet on a 16.5 standard Del'lorto carb with open air filter.
I get no flat spots, not bogging out at full throttle, accelerates all the way to 70mph (on my clock, so true speed is about just over 60).
The last post was made 14 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 82.17 Kb
