| D O G |
 D O G World Chat Champion
| sickpup |
 sickpup Old Timer
| bacon |
 bacon World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
| prawny1 |
 prawny1 World Chat Champion
| D O G |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 08:44 - 15 May 2011 Post subject: |
if you can ''lightly machine'' your old ones, why can't you just make new ones? TBH there's not many things simpler than a brake piston. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| D O G |
 Posted: 09:32 - 15 May 2011 Post subject: |
I can't do it - but a specialist probably would. I was trying to find out if this had been done before by anyone on here.
Don't suppose you fancy making a set of pistons up from stainless, on the cheap?  |
| Serendipity |
 Serendipity World Chat Champion
 Posted: 09:58 - 15 May 2011 Post subject: |
I’m just going through the same dilemma with my old CBR6. I’m going to replace the original rubber hoses with new lines from HEL and I’ve been cleaning up the callipers. I popped out my seals and they’re in excellent condition and reusable once I’ve cleaned the corrosion out of the seats, but my pistons are rather pitted around the top few mm.
However as mentioned above, the pitting on my pistons is only on the bits constantly exposed to the elements so I’ve just cleaned them up as best I can and I plan to give them a go.
How much of the damage to yours is pitting and how much from removal? ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:33 - 15 May 2011 Post subject: |
| Serendipity wrote: | I popped out my seals and they’re in excellent condition and reusable |
I would NEVER re use seals in a brake system.
They aren't that expensive, and its not worth the risk, or hassle.
Brake fluid has a solvent in it, specifically called a 'seal sweller' that soaks into the rubber making seals softer and expand to get a better seal. Once removed they are soft and jelly like, and over size, making them a bloody pain to try and get back in the grooves, and even if you succeed, relieved of tension they wont offer the same seal as when first fitted and then swelled, and are likely to leak or worse pop out.
Your bike, your kneck, your money, but I wouldn't do it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Pete. |
 Pete. Super Spammer
 Posted: 17:35 - 15 May 2011 Post subject: |
There's not a plastics cat in hell's chance of a brake caliper seal ever popping out no matter how old it is. They have an oversize section compared to normal seals and there's almost no clearance between the piston and bore. ____________________ a.k.a 'Geri'
| Serendipity |
 Posted: 18:31 - 15 May 2011 Post subject: |
Well while I can't see one of the fat fluid seals popping out I have experience of dust seals being pulled out after sticking to the piston.
To be fair Teflon has a point. It's not worth fecking about with brake systems for the sake of a few quid. However I know what I'm like with buying parts online. I'll start with seals, move on to new pistons and end up buying new bleed nipples and all new rubbers, pins and springs. Yeah, brakes as good as new, but my pocket lighter by the best part of £150.
The only reason I was considering reusing these seals was that I only fitted them about 1,000 miles ago and they were still well lubed with red rubber grease. However the bike has been stood for nearly five years so I ought to do the right thing and replace them. Last thing I want is to put it all together just to have the brakes start to bind straight away. ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Pete. |
 Pete. Super Spammer
 Posted: 19:47 - 15 May 2011 Post subject: |
Dust seals are a different beast altogether, they are narrow, made from a harder rubber and usually have a relief outboard of the seal groove to prevent the crap they (are supposed to) scrape off the pistons from packing into a tight gap. The reason these come out is because they get stuck to the piston by road dirt when people especially when people fit new pads without cleaning the crap off the pistons and dragged out of their grooves with the piston as the pads wear. ____________________ a.k.a 'Geri'
| prawny1 |
| D O G |
| 0ddball |
 0ddball World Chat Champion
 Posted: 09:50 - 16 May 2011 Post subject: |
| Teflon-Mike wrote: | | Serendipity wrote: | I popped out my seals and they’re in excellent condition and reusable |
Your bike, your kneck, your money, but I wouldn't do it. |
I have to disagree on pretty much every point. I and plenty of other people manage reuse seals all the time with no problem whatsoever. Just as well, as the cost of new ones can be around £100 when you start dealing with 6 pots. Also as said, there is no chance of a fluid seal popping out. The worst you'll get is a leak and a seal has to be in pretty bad shape for that to happen, something that should have been obvious while inspecting them prior to reuse. ____________________ ZXR750L |
The last post was made 15 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
