What the actual fuck. Swingarm eaten by chain tensioner.
Benson_JV
PostPosted: 20:24 - 03 Jun 2011    Post subject: What the actual fuck. Swingarm eaten by chain tensioner. Reply with quote
My chain tensioner has torn back my swingarm as in the picture below. Went along the motorway at about 80 and I thought I smelt burning, so I pulled over as I thought it may have been the new indicator I fitted, it had 3 cables wheras the old one only had 2 so thought I may have fitted it wrong. As soon as I crossed the hardshoulder line I heard a fairly loud 'click' and when I stopped I was greeted by the sight of the chain tensioner at an odd angle grinding against my sprocket and the swingarm torn back like so!
Buying a new swingarm but in the mean time, will this be safe to ride? Also, what the fuck caused it? I had the back wheel out earlier to replace the cush drive but damn I'm not that bloody bad at mechanics.
https://img202.imageshack.us/img202/949/1000709ny.jpg
PostPosted: 20:48 - 03 Jun 2011    Post subject: Reply with quote
I'd attempt to fabricate a new end bit out of a large thicker piece of metal.. I wouldnt ride that, and im riding with forks leaking like a bitch, a tight as a nuns crack chain and a horrendous ticking noise Laughing
Ed Case
PostPosted: 21:22 - 03 Jun 2011    Post subject: Reply with quote
It looks like you missed out a spacer on the drive side of the axle Benson, have a look around on the floor near where you took the wheel out .
Benson_JV
PostPosted: 21:32 - 03 Jun 2011    Post subject: Reply with quote
The floor I did it on is 35 miles away Evil or Very Mad
Do you reckon thats the cause or was that just an observation?
MaybeGuy
PostPosted: 21:33 - 03 Jun 2011    Post subject: Reply with quote
most likely you didn't tighten the spindle enough, then tried some elaborate clutch work.
PostPosted: 21:35 - 03 Jun 2011    Post subject: Reply with quote
Shouldn't really be any great stress on it, so I would be worried about why it happened.
I would check the inside of the arms of the swinging arm. Suspect one has pretty much worn away stopping the spindle clamping the wheel in place.
PostPosted: 21:38 - 03 Jun 2011    Post subject: Reply with quote
The spindle also doesn't appear to be all the way through. There are normally a few threads sticking out past the nut.
There is often a spacer on the inside of the sprocket carrier (between the sprocket carrier and the wheel). These are easily lost/misplaced/dropped.
I'd get it all apart and see what's missing. There may be additional damage to the sprocket carrier and wheel.
No I would not ride it, not even to the end of the road.
Benson_JV
PostPosted: 06:11 - 04 Jun 2011    Post subject: Reply with quote
Damn. That's just about the shittest bit of news I could get right now.
Matt; I didn't do anything too elaborate with the clutch, at the time it happened I hadn't touched the clutch for about 30 miles...
I'm 95% sure I put everything back together properly, but eitherway I'll take it apart at some point and compare against the manual. Have ordered another swingarm. Really can't be fucking doing this, I need the bike for work and I was planning on moving out this month so monies so fucking tight.
garth
PostPosted: 06:49 - 04 Jun 2011    Post subject: Reply with quote
I had this happen to me on the back straight of snetterton on my monster. I'd picked up a puncture so had to get the tyre changed, the bike shop that did it but the spacer that goes next to the sprocket in backwards. This meant they couldn't tighten the spindle up properly.
BAM, shattered tensioner plate, missed my whole day on track.
Benson_JV
PostPosted: 16:00 - 04 Jun 2011    Post subject: Reply with quote
That's a possability... I'll have a look when I dismantle the bike and when I reassemble it I'll make sure I use the manual and follow it properly! Shocked
Benson_JV
PostPosted: 19:07 - 04 Jun 2011    Post subject: Reply with quote
So I've bought a new swing arm. Do I need to buy new bearings or anything?
EDIT: Any idea where to find a chain tensioner from? Ebay/google doesn't have anything Thinking
neil.
PostPosted: 19:57 - 04 Jun 2011    Post subject: Reply with quote
https://cgi.ebay.co.uk/1999-HONDA-CBR-600-CBR600-FW-CHAIN-TESIONERS-/140512799142?pt=UK_Motorcycle_Parts&hash=item20b73729a6#ht_1695wt_907
Is that it?
If in doubt, replace all the bearings, they will be cheap, but you could be in big trouble if they fail! You could try and check the existing one - twiddle your finger around in the inner race, does it spin smoothly? Is there any play/movement/roughness?
Benson_JV
PostPosted: 12:27 - 06 Jun 2011    Post subject: Reply with quote
Thanks for the help neil. Those are the chain tensioners, it says FW but then 1999 Thinking Reckon they'll work?
I'll get to work on the bearings and i'll have a look. It looks like it's going to be at least 2 weeks til this gets fixed. Moving out next week Evil or Very Mad
EDIT: https://www.wemoto.com/bikes/Honda/CBR_600_FV_FW/97-98/picture/Rear_Wheel_Bearing_Kit_with_Dust_Seals/
Is that all I need?
mysterious_rider
PostPosted: 13:11 - 06 Jun 2011    Post subject: Reply with quote
the bearings should have a number on. It's just a case of going on ebay or asking your local bearing shop using this number.
That damage looks absolutely mental. You must be pretty bad at mechanics for that to happen! Laughing I've done some ultimate bodges in the past, including riding a trike with the exhaust ratched strapped to the head (no head bolts) but that's pretty amazing!
Good luck with sorting it out though mate. Thumbs Up
PostPosted: 13:51 - 06 Jun 2011    Post subject: Reply with quote
Don't be too hard on the lad. You should have seen the horrific mess I made of one of my GPZ500s when I missed out one tiny little split pin from the rear brake torque arm.
Totally ripped the footpeg hanger off, chopped the brake lever in half, wrapped the brake rod round the rear hub three times and sliced the end off my boot. I am lucky to still have a big toe.
Benson_JV
PostPosted: 13:59 - 06 Jun 2011    Post subject: Reply with quote
I thought I was pretty average at mechanics, guess not. I'm still not taking it into a bike shop to repair, I'll either fix it 100% myself or kill it 100% myself! Laughing so any bearings I find in the rear wheel I'll replace, any more to look out for that need doing? Like hidden away?
Bloody hell! All the little things eh? We live & learn, I won't be making that fucking mistake again! Never have I ridden so slowly on the motorway, I was doing maybe 45-50, I had the image of the GP rider going round a corner and rear wheel going right past him in my head. Shocked
mysterious_rider
PostPosted: 14:05 - 06 Jun 2011    Post subject: Reply with quote
It's all a part of learning. You haven't hurt yourself and you haven't completely destroyed your bike so it's all good!
Still, it would be great if you could tell us how that managed to happen, personally I'd fix it myself. How else you gonna learn? Just take it easy round the block till you know it's fine.
If you missed out a spacer, wouldn't it be the sprocket bolts that would mash up the swinger?
Could you get a bigger pic of it? Cool
PostPosted: 14:13 - 06 Jun 2011    Post subject: Reply with quote
I would expect a missing spacer to either have the locating studs for the sprocket immediatly chew up the swinging arm (outer spacer) or do it after a few miles (spacer between the sprocket carrier and the wheel).
Personal guess, swinging arm spindle a bit lose (which could happen from a missing washer, worn swinging arm or the first stages of the sprocket carrier bearing collapsing if the inner spacer was missing).
Benson_JV
PostPosted: 14:27 - 06 Jun 2011    Post subject: Reply with quote
I dunno how it happened Doh!
I took my wheel off to replace the cush drive and put it back on. 30 miles later and that!
Here's a bigger picture.
https://img831.imageshack.us/img831/5595/1000710g.jpg
https://img713.imageshack.us/img713/7858/1000711.jpg
mysterious_rider
PostPosted: 14:47 - 06 Jun 2011    Post subject: Reply with quote
Looks like a bad design on the adjuster IMO. Shouldn't that style normally have a cap that covers the whole rear swingarm piece? Rather than just a bit of it?
Can't really see a cap.
Anywho it probably happened because the axle wasn't done up tight enough. Or it came loose, I usually threadlock mine to be safe.
Acemastr
PostPosted: 14:57 - 06 Jun 2011    Post subject: Reply with quote
Yep, there should be a little metal 'cap' that goes over the end with a hole through the middle for the tensioner, god knows how it's munched so much away!
2016 Toyota Tacoma Limited
Benson_JV
PostPosted: 15:08 - 06 Jun 2011    Post subject: Reply with quote
There was a cap! Don't worry I just took it off.
I had to take it off on the side of the motorway to get home as it was grinding against my sprocket.
PostPosted: 15:12 - 06 Jun 2011    Post subject: Reply with quote
On the subject of chain tensioners....
Some adjusters back out of their own accord.
I torqued mine to spec after a normal chain adjustment. 2k later i needed the back wheel out..Adjuster plate was loose.
Like many...i now threadlock mine.(might wire them)
No need for threadlock on my other bike. They always stay put.
totalllama82
PostPosted: 12:48 - 07 Jun 2011    Post subject: Reply with quote
Odd, that actually looks like the spindle hasn't been fully tightened making the chain adjuster 'stop' the rear wheel from moving forward under acceleration....
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
Benson_JV
PostPosted: 18:53 - 07 Jun 2011    Post subject: Reply with quote
Eh? Explain please?
The last post was made 15 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 135.42 Kb
