HELP Suzuki TS 50 ER 1981
Daviddeb
PostPosted: 10:46 - 23 Jun 2011    Post subject: HELP Suzuki TS 50 ER 1981 Reply with quote
HELP.
Hi there im doing up a Suzuki TS 50 ER, 1981 im having problems with the headlight.
The bulb is a 6v/25/25w. the question is should both filaments be on on high beam, at the moment i have only one filament on for high beam and one filament on for low beam. the high beam indicator comes on when in high beam position. i dont know if this is correct, the haynes manual does not give enough info. this means both beams are only 25w, is this enough for a headlight?
Many thanks Dave.
Daviddeb
sickpup
Old Timer
PostPosted: 11:23 - 23 Jun 2011    Post subject: Reply with quote
it's correct. Don't fit a higher wattage bulb, they tend to melt the wiring on those.
Daviddeb
PostPosted: 11:37 - 23 Jun 2011    Post subject: Reply with quote
Thanks, can you confirm then that both filaments dont come on on high beam.
So what makes it high and low then?
Daviddeb
The last post was made 14 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.44 - MySQL Queries: 14 - Page Size: 34.45 Kb
