ybr125 starting
Ayrton
PostPosted: 19:40 - 21 Jun 2011    Post subject: ybr125 starting Reply with quote
hi,
asking this for my brother, but can anyone talk me through how to start a ybr125 2005?
thanks Thumbs Up
RPM
PostPosted: 19:56 - 21 Jun 2011    Post subject: Reply with quote
Hello
Please check your thread in the NB section
Mike
neil.
PostPosted: 21:21 - 21 Jun 2011    Post subject: Reply with quote
Find the choke lever which is on the carburettor (round the back of the engine on the left side of the bike from the perspective of a rider sitting on it). It's a little black lever. You pull it out towards the engine and it'll click into place. Key in ignition, turn it to the 12-o-clock position so it lines up with 'on'. Then either use the kickstart or electric starter (button on the right side of handlebars) and once the engine splutters a bit open the throttle a little at the same time.
Let it idle for a while and watch the revs, once they go around the 4'000 rpm mark, push the choke lever back towards the carb and the engine should idle happily at around 1'000 to 1'500 rpm.
Ayrton
PostPosted: 23:11 - 22 Jun 2011    Post subject: Reply with quote
thanks, thats helpfull. but the problem is that the key wont turn fron off to on.
anyway my brother solved it after. turns out you have to push it in slightly while turning it (not in all the way like when applying the lock). its fussy but it works.
neil.
PostPosted: 05:22 - 23 Jun 2011    Post subject: Reply with quote
Ok... a bit of light oil like 3-in-1 down the key hole (put some on the key itself and work it in/out) will work wonders.
Ayrton
PostPosted: 14:25 - 23 Jun 2011    Post subject: Reply with quote
thanks, il try that.
The last post was made 14 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.44 - MySQL Queries: 14 - Page Size: 47.64 Kb
