TS250 coil - will a 70s coil fit an 80s bike? - See pic..
sandman1976
PostPosted: 19:40 - 25 Jun 2011    Post subject: TS250 coil - will a 70s coil fit an 80s bike? - See pic.. Reply with quote
Quick question, will a coil from a 70s TS250 fit an 80s TS250 & vice versa?
And from the pic attached .... what year ish would you say the engine is?
Anddddd...Can anyone show me a laymans wiring diagram for the coil? Because i thought it would need a cdi unit but im told its a none cdi engine?
Thanks Smile
sandman1976
PostPosted: 20:10 - 26 Jun 2011    Post subject: Reply with quote
Anyone have any ideas on this?
temeluchus
PostPosted: 20:18 - 26 Jun 2011    Post subject: Reply with quote
Get hold of a manual and find out the spec of the coil, youll need to know the number of inputs on the low tension side and the low tension primarys resistance.
You can use pretty much any coil that matches the required spec.
Looks like you have a points engine there.
sandman1976
PostPosted: 20:21 - 26 Jun 2011    Post subject: Reply with quote
So if it has points does that mean its a none cdi unit?
temeluchus
PostPosted: 20:39 - 26 Jun 2011    Post subject: Reply with quote
Yes, if it indeed has points it will not have any form of ignition box.
A mechanical switch controls the power to the coil.
The last post was made 15 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.7 - MySQL Queries: 14 - Page Size: 47.17 Kb
