Bike stalls after oil change....
EazyDuz
PostPosted: 14:04 - 24 Sep 2011    Post subject: Bike stalls after oil change.... Reply with quote
Since i did an oil change to regular 10/40 my bike starts and idles fine, but if i put it in first it stalls, even if the clutch lever is pulled in all the way. This goes away when the bike warms up. It just feels like it wants to lurch forward when its cold.
The old oil was black and thin, is it because the new oil is thicker and its making everything 'tighter'?
Thanks
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
herulach
PostPosted: 20:58 - 24 Sep 2011    Post subject: Reply with quote
The clutch needs adjusting.
YBR 125>FZS600
johnsmith222
PostPosted: 21:02 - 24 Sep 2011    Post subject: Reply with quote
see the twisty bit where the cable meets the clutch lever?
Wind it out a bit.
I take it you've tried with the sidestand up?
EazyDuz
PostPosted: 21:50 - 24 Sep 2011    Post subject: Reply with quote
Wind it out a bit.
If i do that the bite point wont be where i like it...
herulach
PostPosted: 21:53 - 24 Sep 2011    Post subject: Reply with quote
EazyDuz wrote:
Wind it out a bit.
If you don't do that you won't be able to start the bike or disengage the clutch properly, you pick.
YBR 125>FZS600
EazyDuz
PostPosted: 21:58 - 24 Sep 2011    Post subject: Reply with quote
Is there no way to have the bite where you want it?
Im-a-Ridah
PostPosted: 22:03 - 24 Sep 2011    Post subject: Reply with quote
Not unless you disconnect the sidestand switch. You cannot have the bike in gear and on the sidestand, it's a safety feature, so you don't ride off with the sidestand down Wink
herulach
PostPosted: 22:18 - 24 Sep 2011    Post subject: Reply with quote
Thats probably not the issue (although the clutch switch could have gone) the fact that its just after an oilchange suggests that its a genuine stall.
OP - not really, you can move it a bit, but not a great deal unless you have adjustable levers.
YBR 125>FZS600
Glenben92
PostPosted: 11:27 - 25 Sep 2011    Post subject: Reply with quote
Erm... is it not just the clutch plates sticking? seems to be a fairly common occurence. Start it up cold in neutral, pull the clutch, firmly hold the rear brake on and knock it into gear WITH SOME REVS. should be fine from then onwards that day.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
The last post was made 14 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.89 - MySQL Queries: 14 - Page Size: 64.18 Kb
