anyone ever straighten forks.
skikman
PostPosted: 18:40 - 28 Jun 2011    Post subject: anyone ever straighten forks. Reply with quote
hi again.i got a wee ybr yamaha 125 with the forks slightly bent.the bike still rides but you would know its not right.i was thinking could i put them in a vice and straighten them or is that a wast of time?
PostPosted: 18:48 - 28 Jun 2011    Post subject: Reply with quote
You can't strighten them in a vice, but you could do it with a pres and vee-blocks. To check a pair of forks for straightness you can use vee blocks and a dial gauge or if you have no tools simply remove both stanchions and roll them together on a flat surface and look for gaps in between them.
Pete247
PostPosted: 21:52 - 28 Jun 2011    Post subject: Reply with quote
Motoline should be able to straighten them for you if they are not too bad?
Teflon-Mike
tl;dr
PostPosted: 00:09 - 29 Jun 2011    Post subject: Reply with quote
Pete is telling you how its done.... if you have to ask, you probably cant do it! The fork stansion is chromed and then precision ground to provide a 'bearing surface' for the fork slider bush to slid up and down on, and the fork seals to seal against.
If you start bending and bashing with blacksmith type technology (BIG HAMMERS!) you are as likely to do more harm than good and make more problems than you solve.
Damage teh chrome and you'll be looking at £150 to get them rechromed and re ground, after straghtening.
Yes, they can probably be straightened by a motorliner place, or good machine shop....
But YBR forks are available new, from Wemoto and the like for about £30 a leg or something daft..... not really worth the hassle... just get a new one!
skikman
PostPosted: 00:46 - 29 Jun 2011    Post subject: Reply with quote
i cant find any for £30 a leg
Teflon-Mike
tl;dr
PostPosted: 05:08 - 29 Jun 2011    Post subject: Reply with quote
OK, I appologise, remember seeing prices around the £60 mark, I thought was for a pair, so halved it; wemoto, is £99 a leg, others on e-bay around £70... on a quick trawl....
It's still not exhorbitant, when you are talking similar money or more to get a leg straightened or reconditioned.... and you are getting a new bit of metal, thats not been stretched and then stretched back again, and not as strong as it was to begin with... and is a pretty critical structural member..... not something like an exhaust bracket that possibly wont do anything dire if its not that straight or breaks!
The last post was made 15 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.52 - MySQL Queries: 14 - Page Size: 51.93 Kb
