Rebuilding forks - Gap between spacer
Section59
PostPosted: 16:28 - 22 Jun 2011    Post subject: Rebuilding forks - Gap between spacer Reply with quote
Alright people, hoping you can help me here.
Currently re-building my forks on my old heap of a TS200R and having an issue. Just put the forks back together (dry run atm, so i knew what i was doing, apparently i dont..) and there seems to be a gap at the top between the spacer and the spacer holder thingy (technical me or what!).
Once all together, you can lift up the forks a few mm with no resistance and they rattle a bit. Is this simply due to having no oil in them yet, or do i have a bigger issue here?
Don't want to put them back together only to find out i fucked something up and end up with no fork bottoms after a wheelie or something. Everything that came out, went back in, so no missing parts..
Any help appreciated! Karma
MickC
PostPosted: 17:23 - 22 Jun 2011    Post subject: Reply with quote
Don'tknow myself but there is a parts fiche here if that helps:
https://www.bike-parts-suz.com/suzuki-recherche-bike-pieces_nn.php?compteur=2664&PartsListID=1516440
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
MickC
PostPosted: 20:29 - 30 Jun 2011    Post subject: Reply with quote
nah he's on about the internal compnents of the forks (shows you in his pic)
XX XXXx
Teflon-Mike
tl;dr
PostPosted: 20:49 - 30 Jun 2011    Post subject: Reply with quote
Normally there would be NO 'free' movement in a pair of forks, the spring would always be under some 'pre-load', ot when the suspension 'topped out' which it is actually more likely to do more often then bottoming out, load taken off the front wheel when it drops in a whole, or the front wheel is lifted, it would not have any reaction, and would 'slam' into the spring with a shock, when load came back on it.
If everything that came out has gone back in....
Check and double check everything is the right way round, normally springs, or the spacer on top of springs have to be pushed into teh stancion with teh fork cap before you can screw teh cap on.
If all IS as per the pic on teh microfishe or manual, check teh springs free length against specs... likely its buggered! They relax with age and hard work, and go short and feeble.
The last post was made 15 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.8 - MySQL Queries: 14 - Page Size: 51.31 Kb
