chain noise (2 of)
BigGeeking
PostPosted: 22:28 - 30 Jun 2011    Post subject: chain noise (2 of) Reply with quote
Just want to make sure this is normal but when I spin the back tyre by hand in neutral I can here like a rumble of the chain going over the front sprocket!!!
and some times when I change down gears and don’t blip the engine to match engine speed I get like a clanking noise like the chain is slipping on the sprocket it is on my cg 125 2001 I have set the chain tension to 20mm on centre stand as it says in the Haynes but this noise cant be normal
Thanks
Evil or Very Mad
kramdra
PostPosted: 23:29 - 30 Jun 2011    Post subject: Re: chain noise (2 of) Reply with quote
chains do rumble.
the clanking noise might be it hitting the frame. When I got mine I didnt realise quite how often it would need adjusting!
also check the rear wheel is aligned ok, the frame markings are not accurate, and that its got plenty of lube.
Also 20mm sounds far too tight which can be bad.
I would say 30-45mm on my cg. Its suppost to be checked with somone sitting on it.
BigGeeking
PostPosted: 23:52 - 30 Jun 2011    Post subject: Reply with quote
to check aligned wheel can i measure from the rear axal to the swing arm bolt and keep them both the same on each side
DrDonnyBrago
PostPosted: 08:16 - 01 Jul 2011    Post subject: Reply with quote
Yes.
Or you can use the notches on the rear adjuster, or count the number of threads exposed on the bolts, so long as both are the same it will usually be close enough.
The last post was made 15 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.18 - MySQL Queries: 14 - Page Size: 39.38 Kb
