PINLOCK HELP PLEASE!
parkmoy
PostPosted: 13:17 - 22 Jul 2011    Post subject: PINLOCK HELP PLEASE! Reply with quote
Hi, just got a Shoei Qwest and it came with a Pinlock insert to be fitted. The instructions say 'Bend the shield/visor carefully until it becomes flat'.
Heart in mouth I've tried to flatten mine and almost got there, then it seemed that when I got one bit flat, another part popped up so I can't get the whole thing to stay flat and I'm bricking it in case I break it.
Any advice please....
(And yes, I did take the visor off the helmet first, in case anyone asks Very Happy )
mjn51
PostPosted: 13:34 - 22 Jul 2011    Post subject: Reply with quote
slip one end of the pinlock into one of the pins, flatten visor by tucking one end under your elbow until the pinlock fits into the other end of the visor pin and then let go.
M.
Darth
I usually use my hand and sort of half way between my wrist and my elbow. The pinlock can be bent a bit too - just get the correct bit under the pin then flatten the rest down and it'll pop into place.
Kinda hard to explain Confused
Just give it another go - you will have to try pretty hard to actually break it.
parkmoy
PostPosted: 17:42 - 22 Jul 2011    Post subject: Reply with quote
I've given up trying to get it flat. I don't believe it's possible. I've got it fitted using a similar method to Darth and it seems OK.
Quote Me Happy
PostPosted: 17:56 - 22 Jul 2011    Post subject: Reply with quote
The pin lock pins turn and this adjusts the distance between them slightly. This should enable you to get it on properly.
Cunnington
PostPosted: 18:20 - 22 Jul 2011    Post subject: Reply with quote
I locate one end and place the insert in position till about midway across the visor, feed the other end into place and then bend the visor out until it pops into place.
I've got about 3mm play between the insert and the pins when the visor is bent out as far as I comfortably go.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
kawakid
PostPosted: 22:18 - 22 Jul 2011    Post subject: Reply with quote
Yes this is correct. Been wearing pinlocks for years now.
I've a twin and a 4.
parkmoy
PostPosted: 07:23 - 23 Jul 2011    Post subject: Reply with quote
As I said I got it fitted OK but not by flattening the visor. As a matter of interest has anyone actually managed to fit it it as per the instructions, ie have you completely flattened the visor?
mjn51
PostPosted: 07:30 - 23 Jul 2011    Post subject: Reply with quote
not completely flat, just enough to fit pinlock
M.
The last post was made 14 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.95 - MySQL Queries: 14 - Page Size: 57.86 Kb
