| Diehard |
 Diehard Trackday Trickster
 Posted: 23:31 - 15 Feb 2004 Post subject: Had it 5 mins and already problems! |
Ok I got the Gixxer 400 last saturday fully running... Next day it wasn't, had it apart, got it going again with plenty of easi-start on thursday, come saturday, no start! Haven't a clue why, have been checking all that people have sujested and just changed all the plugs today, still refuses to fire. When it was running it sounded amazing, nothing wrong with the engine (touch wood) just wouldn't tick-over without choke. Really miffed with it now! Any help would be great!
What I've done:
Checked fuel tap,
Changed plugs,
Looked at dirphrams for holes,
Checked for blockages in the carbs,
Checked all plugs, they spark ok,
Haven't checked float levels yet, but wanna avoid that if possible. My petrol cap is broken open so would that affect the vacum fuel tap??? Just a thought, please help someone! It's a 1988 GK73A by the way  ____________________ If I Die... I Die! |
| Robby |
 Robby Dirty Old Man
| Demonic69 |
 Demonic69 The Pink Rhino
| chunkielad |
 chunkielad Nearly there...
| mr.z |
 mr.z World Chat Champion
 Posted: 23:36 - 15 Feb 2004 Post subject: |
might be the fuel is a bit manky. has it been left standing for a few weeks/months? thats my only guess really... unleaded can go "off" and do odd things like this... i'm guessing you checked the fuel filter? is there a filter in the tank? try putting it on reserve (if its got one).. these are just silly kind of things that can happen
good luck getting it going again  |
| Diehard |
 Posted: 23:43 - 15 Feb 2004 Post subject: |
Robby always full of words of reasurrance The fuel is new, beacuse I drained it and then refilled the tank the other day just incase, it got rain in from the 2 1/2 hour drive back from where I got it. Also the the fuel filter is in the tap it's self, gonna fit an inline one soon though. Really I think I have checked all I can think of that is ovious but it really baffles me why it ain't going. ____________________ If I Die... I Die! |
| Sparks! |
 Sparks! Sir Tart-a-lot
| Diehard |
 Posted: 23:52 - 15 Feb 2004 Post subject: |
Well Yam normally I would agree but, it ran first time he started it and when I started it later that day, I reccon I'm just cursed to be honest cos my NSR went the same way after I bought that too. Also the guy in the shop had covered the cost of a couple of things I have requested for the general workings of the bike (clutch cable etc) so I can't complain. Well I suppose it's a learning curve, gonna rival keith's knowledge soon!  ____________________ If I Die... I Die! |
| Ste |
 Ste Not Work Safe
| chunkielad |
| Diehard |
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| Kickstart |
 Kickstart The Oracle
 Posted: 00:24 - 16 Feb 2004 Post subject: |
If it is sparking then the chances are the cdi unit is fine.
Water in the fuel is highly unlikely to cause the engine to hydraulic. You get that if you drive through a deep puddle and the engine sucks water in. For a carb the air to fuel ratio by volume is about 10000 parts air to one part fuel, so it is not getting enough volume of fuel to hydraulic the engine.
However it could well be a problem with water in the fuel. This settles to the bottom of the tank so will often cause problems should you turn on to reserve. I would drain the fuel into a large bucket and check what it looks like. Also clean the carbs out again.
| Phoenix |
 Phoenix Twisted Firestarter
| Sparks! |
| Hex |
 Hex Party Boy
| Annabella |
 Annabella Like a person, only smaller
 Posted: 12:55 - 16 Feb 2004 Post subject: |
AI, I would agree with Keith and Gav....
Jimmy's did the same after a long stand, they really don't seem to like getting wet at all. However, after we drained the carbs (easy enough job as long as you have dexterous fingers and extra short allen keys) it behaved perfectly. If you need any tips how to do this, send me a pm.
There has always been an issue with the CDi until on the Gixxer, and charging. So sometimes it needed a bit of a bump. ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
| Demonic69 |
 Posted: 13:05 - 16 Feb 2004 Post subject: |
Whatever you do don't replace the Coils
Stupid feckin bikeshop and their £180 coils.... ____________________ Back on a Blade. Just feels so right. |
| Annabella |
 Posted: 13:09 - 16 Feb 2004 Post subject: |
Dean - I think James' mechanic friend type person put Gixxer750 coils on the 400, for £20 (ish), they seemed to have worked fine. So, yea, don't even bother going to a shop if you think that's the problem, ring round some breakers and get 750 ones if there are no 400 parts. ____________________ Avast! Pirates ahoy!
I did Cadwell!
| Diehard |
 Posted: 14:53 - 16 Feb 2004 Post subject: |
Well the coils seem fine, all plugs firing with their relevent coil connection. Also when I had the carb off I had it upside down and everything. Thought water would have come out if it was going to. But gonna try drain the floats out to make sure (stand by your pm Annabella but not for a day or two). I got the clutch cable on last night and tryed to bunk it but with no luck (plus I live on a hill and the bike has no breaks at mo), so I really was chasing it down the street! ____________________ If I Die... I Die! |
| Diehard |
 Posted: 01:38 - 22 Feb 2004 Post subject: |
Ok, took carb completely off, drained floast bowls. Opened them up, cleaned all of the jets, scouped (yes I said scouped) the crap out of the bottom of the bowls, put it back together and started first time! BUT One of the float bowls has a crack in it so fuel slowly drips out. Therefore if I leave the bike over-night I have to prime the carbs again the next day. ALSO the bike is possesed! It throttles it's self. Ticks over at variable 8,000 revs and randomly flicks up to 12,000 revs and I have to pull the throttle back to reduce the revs! Weird I know, must be a air leak, but any ideas anyone? ____________________ If I Die... I Die! |
| Sparks! |
| Diehard |
| Sparks! |
| Phoenix |
The last post was made 22 years, 180 days ago. Instead of replying here, would creating a new thread be more useful? |
