adamcfc |
adamcfc Borekit Bruiser
Posted: 23:00 - 30 Jul 2011 Post subject: Honda CBR 125 - a few minor problems |
Just purchased a Honda CBR 125, it has a few little problems, just wondering if anyone can give some advice.
1) On de-acceleration, and after the bike has been revved and the revs are dropping, flames pop out the exhaust every now and again. This is a sign the mixture is too rich? To fix this i must adjust the mixture screw on the carb?
2) The bike idles at about 1200-1400 rpm, but its a little bit erratic. Is this irregularity a sign of a rich mixture, or should i adjust the idle screw on the carb to allow the bike to idle at 1600-1800?
3) Apon trying to start the bike today, the starter motor turned over twice then stopped, the lights dimmed and the indicators wouldnt flash. I bump started it, and then everything worked fine. I left it running for 5 mins, turned it off, and it then started on the button again. I checked the voltage with a multimeter, and found the resting voltage was 12.02 DCV and the power when running was 12.75 DCV.
Am i right in saying a good battery should hold about 12.5+ when resting, and that the bike is going to fail to start in the morning?
Finally, where is the mixture screw on the carb, and how many turns in or out should i try? I know the idle screw points down out the carb, has a flat screwdriver slot, and has a spring on.
Any help is appreciated, Many Thanks,
Adam |
adamcfc |
neil. |
neil. World Chat Champion
R6 Wilson |
R6 Wilson Trackday Trickster
ThoughtContro... |
ThoughtContro... World Chat Champion
adamcfc |
ThoughtContro... |
neil. |
adamcfc |
CarlosCBR |
CarlosCBR World Chat Champion
unitynotsocri... |
unitynotsocri... Banned
Posted: 20:33 - 01 Aug 2011 Post subject: |
As other posters sounds like its running rich.If the mixtures are set right and it continues then it might be a choke sticking problem(if it has old style choke)
The battery could be goosed or need a good charge,
backfiring on the overun is usually because of a rich mixture.Unburnt petrol ignites in the exhaust.Hence your sooty plug.
if you fit a charged/new battery and the voltage(when running)is below 13.5 to 14 volt then theres a problem with the voltage regulator or alternator or an earth short from a live wire,Indicators with water in em can cause this fault.
never bother starting up the bike with the headlight on as the battery won't last as long.the extra current stresses the battery more. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
ThoughtContro... |
unitynotsocri... |
Posted: 21:16 - 01 Aug 2011 Post subject: |
Thanks for info Thought Control,
then its mixtures ,and probably a tired battery. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
adamcfc |
Posted: 10:00 - 02 Aug 2011 Post subject: |
Quote: | Does the bike have an aftermarket exhaust? The mixture screw is on the left hand side of the carb. |
Yes Carlos, it has a full Yoshimura system, absolutely massive
Quote: | The choke on the little CBR is pants. If you leave it on after you've started the bike and the engine starts to warm up, as soon as the revs fall back to idle the engine will cut out.
I find the choke is awful on this, so its not just me? If i start the engine, then pull the choke out the bike just dies.
So, the mixture screw is on the left side of the carb? Is it easily distinguishable? I need to turn it IN to LEAN the mixture, i shall start with half a turn, other than checking for no backfires, how can i check the mixture will then be okay?
Also, with the battery, the bike hadnt run for a few months until the short ride from the sellers house back to mine. Once i got back i turned the ignition on to fix a sticking mainbeam switch, maybe this could've drained the last of the battery. I will leave it running for 10 mins and see how it goes from there.
Thanks Again, Adam |
adamcfc |
Posted: 21:54 - 02 Aug 2011 Post subject: |
Heres a picture of the bike:
And the Yoshimura system |
ThoughtContro... |
There is a gap of 1 year, 248 days between these two posts... |
Clutchy |
Clutchy World Chat Champion
unitynotsocri... |
Posted: 01:07 - 13 Apr 2013 Post subject: |
best way is to test the alternator.
each of the coils,wether alternator or single/simple coils all have a 'resistance.You can measure the resistance and check wether a coil is broken or short circuited.
by removing the alternator connector block you can measure with a multimeter and check against spec.
Bulbs are prone to corrosion at the base and pins and sides.The lead contacts corrode easily and an indicator without a seal on the lense,or a crack soon soaks up water.
I'd check the way the indicators are wired in,as in make sure its standard.An unfused bodged in live feed to an indicator relay could cause power problems if earthed through a soggy indicator.
check the alternator first though,
and if in doubt slap another earth wire from the engine to the frame........... ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 11 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
