Is my helmet too small?
c_dug
PostPosted: 12:24 - 31 Jul 2011    Post subject: Is my helmet too small? Reply with quote
I bought myself a new HJC helmet last Saturday, if feels comfortable enough, if a little tight, but everybody keeps reassuring me it will ease off with wear.
My problem is that it leaves a very obvious red mark on my forehead which takes about 10 minutes to go, it's bad enough that people think I have head-butted somebody. To me that sounds like it is too tight?
I usually end up with lids that are a little too big, so I'm not sure how tight a well fitted helmet should feel.
PostPosted: 12:28 - 31 Jul 2011    Post subject: Reply with quote
It might be a tiny bit too tight but give it a few more weeks and it will probably bed into the shape of your head.
kingsmith
PostPosted: 12:32 - 31 Jul 2011    Post subject: Reply with quote
they will ease of with use, mine is still tight as hell but better to be a good fit then something that lifts and loose as hell..
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
PostPosted: 12:40 - 31 Jul 2011    Post subject: Reply with quote
Probably bad to admit this... but I took a stanley blade to the front padding on my batman lid, kept leaving a solid mark on my head... skimmed a few mm off and it was perfect.
Still in use also Laughing
c_dug
PostPosted: 12:51 - 31 Jul 2011    Post subject: Reply with quote
I've considered it, I'd rather do that than waste the £160 I spent on the lid.
R6 Wilson
PostPosted: 13:45 - 31 Jul 2011    Post subject: Reply with quote
Exactly the same as my mate with a YBR, every time he pulled it off he had a massive red square on his forehead that took ages to go, he told me the more he wears it the less tight it'll be till he ended up buying a new AGV K3 the other week Thinking
But still, better tight than loose Thumbs Up
♥ YZF-R6 '05 ♥
Time is money so I stay late
Deckx
PostPosted: 14:06 - 31 Jul 2011    Post subject: Reply with quote
i would say as long as the hard padding is not pressing against your head it is ok.... i actually have a size Small HJC which is a really snug fit ( the M and L feels ok as well ?)... .. i think the basic shell is the same size except they increase the padding for different sizes so shouldn't matter to play with the soft pads ....not sure i would go shaving the outer shell though?
Rob W
PostPosted: 14:59 - 31 Jul 2011    Post subject: Reply with quote
Surely that's a question only your missus could answer?
On a serious note, as long as it isn't uncomfortable to the point of giving headaches it'll be fine. My Spada lid was tight as aresholes when I got it, but not uncomfortable and within a couple of weeks had bedded in nice and feels perfect on. It's better to put up with a bit of tightness for a little while than have a loose and sloppy feeling lid in the long term.
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
andys675
PostPosted: 15:57 - 31 Jul 2011    Post subject: Reply with quote
knew a guy with a similar problem with one of those shark flip fronts, I pulled back the fabric lining and there was a square foam pad stuck to the EPS, peeled it off and gave it back to him, no problem!
trevoriv
PostPosted: 16:05 - 31 Jul 2011    Post subject: Reply with quote
My lid was doing the same but was a good fit on the cheeks etc so I bought the top removable lining insert from the size above and that sorted it. Not sure if your lid has the removable lining though Confused
wiltsgixer
PostPosted: 19:30 - 31 Jul 2011    Post subject: Reply with quote
ooohh I thought this was going to be a smutty post given the title...Sad I have found the cheaper the make of lid, the more/ quicker they loosen up. When I say cheap I dont mean that rudely. I just mean the lids costing less seem to bed in and give much quicker and further. IE my RST lid which i love but was cheaper than my Arai has loosened up further and quicker. Give it some more time I would. Unless it is actually painful to wear and is distracting. Then I would say you might have to rethink.
Gerrard
PostPosted: 21:27 - 31 Jul 2011    Post subject: Reply with quote
I'd give your lid a little more time to give a little.
Honda Blackbird the great all rounder.
Chillin near Malaga.
Marco Simoncelli 58
The last post was made 14 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.03 - MySQL Queries: 17 - Page Size: 76.26 Kb
