Front Shock/Suspension seized up
Zeuky
PostPosted: 16:15 - 10 Aug 2011    Post subject: Front Shock/Suspension seized up Reply with quote
'ello boys n girls!
Just took the bike round the block and found the forks aren't moving. I'm bobbing along, pull the front brake firmly and it's just an awkward stop where the front of the bike doesn't dip Confused
I've called my local garage, and they've booked me in a visit for next Tuesday (16th August) but I was wondering if there's anything I can take a look at in the meantime? I've bugger all mechanical expertise, so any help in idiot form is really appreciated Mr. Green
Thanks muchly!
Oh it's a BMW K1200 RS by the way.
This is some shit from the manual if it helps
https://i1220.photobucket.com/albums/dd448/Zeuky-Dooky/Forks.jpg
"S'cuse me mate but you left something under your car... think they call it a 'KEEP CLEAR' sign... No no, i don't need to go down that road to get to where I LIVE. Proposterous!"
https://www.CrunchySlipper.co.uk/
Frost
PostPosted: 16:38 - 10 Aug 2011    Post subject: Reply with quote
I suspect the contents of the gas filled strut have made a successful bid for freedom.
steven_191
if you can, i would start by...
support the front of the bike and unbolt the front shock. check if the forks move and the linkage moves. if it does, could be the shock. if it doesnt then you need to check the linkage and forks.
but to be honest, if its already booked in, theres no point messing around with anything. you still got to ride it there havent you??
finpos
PostPosted: 16:54 - 10 Aug 2011    Post subject: Reply with quote
For fear of sounding stupid, is the whole point of the telelever suspension that it does not dip under braking?
Edit Wikipedia says:
This system both lowers unsprung weight as well as decouples wheel placement function of the forks from the shock absorption function - eliminating brake dive and providing superior traction during hard-braking situations. This system improves comfort and stability considerably while providing excellent and sporty handling.
f.
Frost
PostPosted: 18:06 - 10 Aug 2011    Post subject: Reply with quote
I thought it gave a degree of anti dive, but wouldn't keep the bike totally level when braking? Ultimately the weight shifting from deceleration will compress the front end, the telelever system just maintained a constant rake angle making handling more consistent under braking? Either way pulling in the front brake to stop the bike rolling forwards and pushing the bars up and down should compress the front end.
The last post was made 15 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 14 - Page Size: 44.17 Kb
