Removing engine cover for fixing oil leak Yamaha R1 (2001)
aetius
PostPosted: 11:34 - 15 Aug 2011    Post subject: Removing engine cover for fixing oil leak Yamaha R1 (2001) Reply with quote
Hi,
I've got a slow oil leak on my R1 right hand side, it's coming from the black engine cover (as shown in the pic). I've removed all the alan key bolts from around the cover (the three shown in the pic were just put in place to hold the cover back in place temporarily), but still can't remove the cover.
I noticed 3 small lips at the back of cover, which I can pull on and slightly move the cover, but it doesn't come off completely. I wanted to remove the cover, replace the seal and add some gasket/oil sealant all around.
I'm having trouble removing the cover, can anyone advise how to do this? Despite all the Alan bolts being removed, the cover only moves slightly and is stubborn to remove.
Failing to remove the cover, I may just add sealant all the way around the cover - would this be adequate?
Any advice is much appreciated.
Black cover shown below in 2nd pic
Thx
Dan
PostPosted: 11:47 - 15 Aug 2011    Post subject: Reply with quote
Slacken/unhook the clutch cable and try again. Don't put sealant on it, buy a proper gasket it will only cost £5-10.
MarkJ
PostPosted: 13:00 - 15 Aug 2011    Post subject: Reply with quote
As above. Unhook the cable, take out the dipstick and give the casing a few good knocks with a rubber mallet. Be aware that it may be being held in position by metal dowels so might not just drop off how you're expecting it to. You might also be able to prise it apart with a screwdriver but make sure you don't damage the mating surfaces.
aetius
PostPosted: 14:22 - 15 Aug 2011    Post subject: Reply with quote
Cheers for the tips guys, will give it a go tonight
thx
The last post was made 14 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 14 - Page Size: 38.95 Kb
