| Author |
| shereen |
 shereen World Chat Champion
 Posted: 20:59 - 15 Aug 2011 Post subject: HRC Ignition Unit |
What do they actually do? Is it worth the money getting one? Will it noticable improve my bike performance?
I have heard conflicting advice regarding the damn little box!!
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260833191382&ssPageName=STRK:MESINDXX:IT
Last one I saw on egay went for over £200. ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| Back to top |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Back to top |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 08:00 - 16 Aug 2011 Post subject: |
All it does is increase the rev limit and alter the ignition cuve slightly. ____________________ My Flickr |
| Back to top |
| shereen |
| Back to top |
| Blau Zedong |
 Blau Zedong Banned
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
| Frost |
 Frost World Chat Champion
| Back to top |
| shereen |
| Back to top |
| Billing |
 Billing World Chat Champion
 Posted: 15:09 - 16 Aug 2011 Post subject: |
Even though you've made your decision, just wanted to say don't bother with it, for £135 you can get an Ignitech CDI which will do everything that HRC box claims to do and more.
I have one on mine, and was very impressed, no restrictions, and it's slightly better in the midrange, it can be loaded with a HRC map if you have the rest of the setup  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Back to top |
| Frost |
| Back to top |
| shereen |
 Posted: 15:26 - 16 Aug 2011 Post subject: |
| Billing wrote: | for £135 you can get an Ignitech CDI which will do everything that HRC box claims to do and more.
I have one on mine, and was very impressed, no restrictions, and it's slightly better in the midrange, it can be loaded with a HRC map if you have the rest of the setup  |
Someone else told me about these ignitech bad boys! Maybe I will look into the then if you rate them
| Frost wrote: | Actually it does make 2 differences:
Removes the 112mph speed restriction, but so does adding in a resistor behind the clocks, adding a speedo converter and a few other things.
Removes the rev limiter. I found this out when I got mine off the scale overtaking my dad. Probably useful if you've done some serious engine modification and the limiter is kicking in too early for your newly shaped power curve, but for 99% of NC30's it just makes it easier to damage the engine.
Mine is already de restricted and I dont really fancy ragging the nuts off it too much after all the money I have spent fixing it But thanks for the information
| Frost wrote: | The RVF USD's are internally the same as VFR forks, they mostly just look nicer. So getting your current forks serviced and some progressive springs would do more for the ride quality. |
I was told USD's make a massive difference
Billing, you have USD forks no? ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| Back to top |
| Chriss |
 Chriss World Chat Champion
 Posted: 15:33 - 16 Aug 2011 Post subject: |
Rather than going for bog standard USDs, I'd personally just pay for Maxton to rework your current ones. Much better bang for your buck and you will notice a huge difference.
Unless your shock is standard and old, in which case I'd spend the money there first, since that's the best change in suspension you can make, in my very humble suspension addicted opinion.  ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
| Back to top |
| shereen |
| Back to top |
| Billing |
 Posted: 16:03 - 16 Aug 2011 Post subject: |
I got the USD's for the looks, I'll admit it, I'm a tart but they do give provision for better brake calipers (gold ones from the SP1/2 etc)
If you do want an ignitech, shout me, I'll help you get one from the same place I got mine, come with the software CD and a cable to run to a computer (you'll want to spend the extra to get the adaptor unless you have a 9 pin serial port on your laptop)
Get me a picture of your shock, I'll tell you what it is, and whether it's rebuildable. I've been advised that if on a budget you're best off having the stock one rebuilt, it's good enough when it's in good condition  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Back to top |
| Chriss |
| Back to top |
| Chriss |
 Posted: 16:11 - 16 Aug 2011 Post subject: |
For what it's worth too, if you do want USDs for the tart factor then before fitting them it's probably worth having them rebuilt by a company such as Maxton (I mention them because I've had excellent service from them before). I only bought an Ohlins shock over getting mine rebuilt because I was a tart.  ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
| Back to top |
| Billing |
 Posted: 18:45 - 16 Aug 2011 Post subject: |
Just remembered that convo we had about the redbull can on the shock reservoir on some bikes. You have a later shock, which IS rebuildable, so there's good news there
From what the guys on greybike have said there doesn't appear to be any difference between the HRC box and a 2.2k ohm resistor, apart from it says HRC on it! I don't think anyone has been brave enough to crack one open to see whats actually in it though. ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Back to top |
| temeluchus |
| Back to top |
| shereen |
| Back to top |
| Chriss |
 Posted: 09:53 - 17 Aug 2011 Post subject: |
| shereen wrote: | So spend the money on getting the shocks rebuilt? How much does that cost ball part figure? |
About a year ago, I paid £50ish for the rebuild plus any additional parts required. Then throw VAT on top of that.
I've literally just phoned Maxton, Richard the guy who normally deals with enquiries is on holiday at the moment. They don't rebuild OEM shocks any more, since often parts aren't available any more, so they've taken your shock to pieces and they can't rebuild it for lack of getting parts. They couldn't recommend anyone purely because they've not seen the quality of the work.
New thing I've learnt though, Maxton shocks can be rebuilt to fit your new bike. So take your shock off, place their one on. They can obviously service their own shocks. Then when you sell the bike, swap the shocks round again, send the Maxton shock off to them and they're adjust it to fix your new bike.
The above isn't always possible, but may be of some use.  ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
| Back to top |
| shereen |
 Posted: 09:56 - 17 Aug 2011 Post subject: |
| Back to top |
| Chriss |
 Posted: 10:05 - 17 Aug 2011 Post subject: |
Just edited my post above to include more information.
They start at £415 + VAT.  ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
| Back to top |
| shereen |
| Back to top |
| Chriss |
 Posted: 10:32 - 17 Aug 2011 Post subject: |
| Back to top |
The last post was made 14 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
