mikey c |
mikey c Derestricted Danger
Kickstart |
Kickstart The Oracle
mikey c |
Posted: 19:46 - 27 Feb 2004 Post subject: |
thanks for the reply!
i was just wondering, on our engine there is an extra 20mm between the centre two ports because of the drive to the cams,
https://muchos.co.uk/members/Mikey%20c/DSC31302a.jpg
on other engines this is at the end of the head, so the ports are exactly the same distance apart accross the head. I think this may be the case on the F4i, see this picture all the ports look the same distance apart
also the origional carbs are 32mm, the F4i has 38mm ones, you reckon i'll have to make adapters to reduce the bore to fit the head?
thanks |
Kickstart |
mikey c |
Posted: 17:27 - 29 Feb 2004 Post subject: |
thanks for that, i thought as much but i wanted to be sure,
now i'm thinkin of puttin the carbs back on, but it would be a shame not to use the EFi system, so i was thinkin of having injectors pointing down the trumpets, similar to the twin injector set up on the CBR600RR, with the carbs taking care of idle and low speed/throttle openings.
trouble is i'm no expert in carbs, its got the butterfly throttle, and the slide bit, if i disabled the slide and held it open, and blocked the main jet, would the idle and progression part still work (or is that part of the slide?) and have the injectors taking care of fuelling from there onwards, got any opinions on this??
thanks for the help!
mike |
Kickstart |
mikey c |
The last post was made 20 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
