| ProXimaCore |
 ProXimaCore Dougal
 Posted: 17:34 - 28 Feb 2004 Post subject: New exhaust and end can joining. |
Hello, I was wondering if someone would be kind enough to help me with this...
How do I seal an end can to the exhaust? I have the 2 new parts but they aren't welded together or anything and they come apart. I assume they can't just be put together as they are.
Also, I've been told to get the Jets changed for putting it on. Then when I asked the guy in the bike shop today he was told by the manufacturer of the system to leave it as it is. It's an 'Arrow' exhaust for a 'NSR125R'. Anyone shed any light there?
Just got my bike Serviced and new chain and sprockets fitted, so today seems like a good day to derestrict the thing. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
 Posted: 17:40 - 28 Feb 2004 Post subject: |
Hey mate how you doing?
Sounds strange that it came in bits. From all the pictures of Arrow and Jolly Moto exhausts for the NSR they seem to come as a complete unit, just like standard one. Sorry can't offer more help.
Maybe just get local garage to weld it?
Let us know how you get on.
Mark ____________________ Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..." |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 17:46 - 28 Feb 2004 Post subject: |
Well I got it used rather than buying it new. Doesn't look like it's ever been welded together but they do fit together quite tight. I don't want to go ahead and just put it on incase it should be welded. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| rossi_46 |
 rossi_46 Borekit Bruiser
 Posted: 21:39 - 28 Feb 2004 Post subject: |
Hi, i sold him this exhaust, i had it on my NSR125r, this is the correct one for his bike.
I suspect the reason for the end can being separate is because you can get a replacement end can, crash damage and the like.
To seal the exhaust, i used that thin tape that when heats up, it forms a seal, cant remember whats its called, but does the job.
On the jetting side of things, at your own risk, put the exhaust on, and not jet it.
I would recommend that you do, get a dyno session booked, to have her running sweet.
Honda supplied me with this system, and they told me, that it didn't say to jet it, but when i rang every where else they all said , you don't jet it, it will blow.
I also got the power valve to open a bit later, which worked down a treat.
Hope this helps. |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 21:45 - 28 Feb 2004 Post subject: |
That's some good info. Thanks. Do you remember what jet size you used when you had it fitted?
Anyone know the name of that seal tape is that Rossi_46 mentioned? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Dr Nick |
 Dr Nick World Chat Champion
| AcIdBuRnZ |
| Gti |
 Gti Bendy Groupie
| G |
 G The Voice of Reason
 Posted: 11:39 - 29 Feb 2004 Post subject: |
25hp from a 125... so that's 200hp per litre.... F1 cars that rev to 18k rpm with all sorts of fancy bits only make a bit under 300hp per litre I believe . (Okay it's not that complex engineering, but it relativly a pretty highly tuned engine, so things like jetting etc can make a fair bit of difference if you do lots of other little bits.
The majority of full systems are designed to work best with rejetting at least. Even with an end can it's usually best to get some work done to make full use of it anyway. |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 12:26 - 29 Feb 2004 Post subject: |
I've also stripped my bike down just now and I was about to take out the Intake Restrictor. Should I take it out now or should I wait till I can get the new exhaust on? The original one is still restricted.
p.s. that little tray thing will NOT tilt back! Any tips? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Laura |
 Laura Playboy Bunny
| MarJay |
 MarJay But it's British!
 Posted: 12:55 - 29 Feb 2004 Post subject: |
Um, on the subject of rejetting, if you don't rejet you might run dangerously lean and then your engine will seize...
2 strokes are actually MORE tempramental as far as that stuff goes than 4 strokes.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| rossi_46 |
| Dr Nick |
 Posted: 13:09 - 29 Feb 2004 Post subject: |
It's the same as the RS50 arrow exhaust, the reason why i didnt get it. The RS125 and Mito got a new bigger exhaust system . ____________________ is that it |
| Kickstart |
 Kickstart The Oracle
| rossi_46 |
 Posted: 13:34 - 29 Feb 2004 Post subject: |
Hi, kickstart, when this happened to the two other nsr's , they came to me, and said would i go up to the dealer with them, if there bike blew up, and mine didn't , i could maybe show them the difference on the dyno report.
The Honda dealer was not looking to fix it for them, but, when I showed them Dyno graph before the jetting took place, it was running lean, and the after which the jet change took place, was fine , a nice clean line.
At the end of the day, there Honda book said no jetting was required, which if was true, the problems would not of been caused.
Apart from this , Honda aren't stupid with things, I love Hondas to bits, hence i've always had a Honda of some sort. |
| Kickstart |
 Posted: 13:50 - 29 Feb 2004 Post subject: |
| rossi_46 wrote: | The Honda dealer was not looking to fix it for them, but, when I showed them Dyno graph before the jetting took place, it was running lean, and the after which the jet change took place, was fine , a nice clean line. |
Honda themselves can quite happily say get stuffed under UK law. For a start the bike was being worked on by a non Honda dealer.
| rossi_46 wrote: | At the end of the day, there Honda book said no jetting was required, which if was true, the problems would not of been caused. |
But Honda do not sell the Arrow exhaust, and have nothing to do with Arrow. The dealer might sell them, and might have a catalogue but that is nothing to do with Honda.
| rossi_46 |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:12 - 29 Feb 2004 Post subject: |
I just pulled out what should be the intake restrictor. I'm not sure though. I've got down to the place where it was meant to be but instead of a plate being there with a circle hole in it, there's this pyramid type thingy I've pulled out with 6 white flexible plastic bits on it. What the hell is that? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Korn |
 Korn Admin
 Posted: 14:15 - 29 Feb 2004 Post subject: |
Erm, that's the reed block... put it back! ____________________ 3516 Miles, 11 Countries |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:16 - 29 Feb 2004 Post subject: |
I figured it'd be something like that.... Where should the intake restrictor be in relation to that? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| rossi_46 |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:23 - 29 Feb 2004 Post subject: |
That's what i've been working from, but that plate isn't there. The first thing I came to was the reed block. The reed block hole seems to get smaller towards the end like it has the restrictor built into it. Is that just normal? Does it appear to be derestricted there already then? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Korn |
 Korn Admin
 Posted: 14:35 - 29 Feb 2004 Post subject: |
If the plate isn't there then it isn't there... The reed block is supposed to be that shape and the white plastic piece isn't a restrictor, it serves to smooth the flow of air. ____________________ 3516 Miles, 11 Countries |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:37 - 29 Feb 2004 Post subject: |
Brilliant! Thanks for the help on that one. On to the exhaust now....  ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
The last post was made 22 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
