Another light problem!
R1stu
Shrek!
PostPosted: 11:35 - 01 Mar 2004    Post subject: Another light problem! Reply with quote
Well after having the R6 serviced, they told me that the main beam no longer works. Confused It did a few days before, and i'm thinking that the snow may have had something to do with it?
When you put the high beam on, the lights go out (side and rear stay on ok). However if I press the "pass" button the main beam will flash as normal.
On some instances if I put main beam on and then press the "pass" button the lights will stay on normally until I put them back onto the normal light!
Any Ideas?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 11:49 - 01 Mar 2004    Post subject: Reply with quote
You've been riding around without the front fairing havn't you?
I would guess that there is water in the switch gear or the connections. Unplug it all, squirt a load of WD40 in, let it dry a bit then try it again.
Or just ride around holding the pass switch down Wink.
The last post was made 20 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.51 - MySQL Queries: 17 - Page Size: 33.25 Kb
