R6 Track day exhaust
Blackrandomap...
PostPosted: 14:04 - 24 Aug 2011    Post subject: R6 Track day exhaust Reply with quote
Hey folks,
Just been down to castle coombe to get my bike sound tested. It came in at 124DB when most track limits are 105DB
Has anyone got any ideas on what exhaust to get that will be under 105DB?
Currently using a RACE-FIT but even with the baffle fitted its 120db
Thanks!
James
1x 2001 Yamaha R6 1x 2000 Yamaha R6 !For Sale! £2500 1x 2003 Cbr600rr Racebike 1x 2004 Wr450 Sumo 1x 2001 Ktm520 Sumo
SuzukiTom
PostPosted: 15:37 - 24 Aug 2011    Post subject: Reply with quote
120 will see you fail at pretty much any noise restircted day. I know castle coombe have turned away totaly sotkc bikes for failing the noise test.
For a track day at CC i would put the stock exhaust on IMO.
Blackrandomap...
PostPosted: 16:23 - 24 Aug 2011    Post subject: Reply with quote
Yeah, did notice a lot of people with stock exhaust bar the ducati's
So it looks like im gunna have to use my stock can, Shame cos my bike it slow with it on!
DynaMight
PostPosted: 17:00 - 24 Aug 2011    Post subject: Reply with quote
Castle Coombe measure the sound very differently than most tracks. What RPM's did they get you to rev to and how far away was the Db meter?
Other tracks use the ACU method, which is 7.5k rpm (for a 600cc machine) with the Db meter 2 foot away at a 45 degree angle. Most race cans without baffles will pass. Some tracks have a driveby test, so you can always rev lower past those points.
Some tracks like Mallory Park dont even have a noise restriction, the TDO will say its 105Db, but there is none.
If its a carb'd R6, and hasnt been setup for the new can, I expect it'll run just as well with a standard can.
Blackrandomap...
PostPosted: 17:30 - 24 Aug 2011    Post subject: Reply with quote
It was measured at 12'000rpm at around 2ft from the exhaust at about 20 degrees.
Unfortunatly my bike has been set up to the race can Sad
will it make a big difference in power? will it do it any harm?
Thanks
SuzukiTom
PostPosted: 19:04 - 24 Aug 2011    Post subject: Reply with quote
Thanks
is it carbed or FI?
some bikes get effected more than others - was it a can or a full system?
Blackrandomap...
PostPosted: 21:23 - 24 Aug 2011    Post subject: Reply with quote
Carbed! just the end can!
PostPosted: 21:26 - 24 Aug 2011    Post subject: Reply with quote
Bunging the stock can back on for the day won't hurt it. You may find it's slightly flatter than usual if it's been jetted to suit.
Can't say I believe you'll be noticably slower. At most you'll lose 2-3bhp.
Blackrandomap...
PostPosted: 21:29 - 24 Aug 2011    Post subject: Reply with quote
should be fine then, probably feel wierd to ride if it sounds so different.
Looking at doing malary park on sat 9th! some say there not to bothered on sound, will take stock can anyway!
is malary park any good?
swiftb
PostPosted: 23:39 - 24 Aug 2011    Post subject: Reply with quote
just bung the standard can on. Youl likely notice a power loss or fairly big flatspot if its jetted for the reacefit -but other than that not really an issue - depending where the flatspot is (if there is one) you can usually clutch it when its about to bog to get past it.
Blackrandomap...
PostPosted: 08:27 - 25 Aug 2011    Post subject: Reply with quote
Thanks for your info guys!
0l0dom0l0
PostPosted: 23:41 - 25 Aug 2011    Post subject: Reply with quote
Could always look out for something like a viper as they are in the middle!
The last post was made 15 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.63 - MySQL Queries: 14 - Page Size: 70.86 Kb
