Honda CB 900 Bol d'or FA/FZ history?
MickC
PostPosted: 22:03 - 04 Sep 2011    Post subject: Honda CB 900 Bol d'or FA/FZ history? Reply with quote
Does anyone know the history of these bikes or where i could get the info (in a USA based forum as well and there is quite a bit of discussion as to which models are actually Bol d'or's)?
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Shaft
PostPosted: 23:26 - 04 Sep 2011    Post subject: Reply with quote
In my memory (which cannot always be relied upon) in the UK only the fully faired FII was called Bol d'Or and they carried that forward to other models which they subsequently offered with full fairings, after launching as naked or semi naked bikes, like the CBX750.
However, I believe that even the naked 900F was called Bol d'Or elsewhere in Europe and the colonies.
ETA: a door has just creaked open in the dark recesses of my mind, behind which is the information that the Bol d'Or tag only applied to the bikes in the red/white colour scheme, but I'm less certain of that.
T.C
PostPosted: 09:30 - 05 Sep 2011    Post subject: Reply with quote
Probably the best bike I ever owned, or to be more accurate probably the bike I had the most fun on.
I had an 85 model back around 1987 (funnily enough I found the pictures of it the other day), and I loved every moment on it.
The original 900FA (unfaired model) had various teething problems as it was one of the early follow ons from the 750.
In the UK, we started with the CB900F2B which came with probably the best fairing on any bike.
The Bol D'or was the later bike (although I think they used this designation in Europe throughout its life) and if memory serves was the last of the range before it got dropped, although spec remained pretty much the same apart from the back tyre becoming a little wider.
Not the fastest bike (about 140 was probably its top speed) but supremely comfortable, probably the best mirrors on a bike until the Pan European improved things, easy to work on, and although quite heavy, that vanished once rolling.
The only things that ever really tended to go wrong, and even then it was not really a fault was that the starter chain tended to get a bit noisy (something Honda called a mid life crisis) around the 60,000 mile mark, and when changing the plugs care had to be taken as it was very easy to cross thread which meant a heli coil job.
But that apart? Terrific bike if you can find a good one which may be difficult as they have been out of production since about 87/88/
It is better to arrive 30 seconds late in this world, than 30 years early in the next
Tenko
PostPosted: 09:47 - 05 Sep 2011    Post subject: Reply with quote
Didn't the Bol'Dor come with different wheels to the standard CB900FII?
T.C
PostPosted: 10:40 - 05 Sep 2011    Post subject: Reply with quote
Probably as the Bol had a wider section front and rear tyre.
MickC
PostPosted: 17:50 - 05 Sep 2011    Post subject: Reply with quote
Bit of info from a foreign site, (might take a few seconds to load):-
Cheers Vincent, that should clear it up (the debate is which models were classed as bol d or and from that page in your first link it does state all of them from 79-83 were classed as it.
XX XXXx
Shaft
PostPosted: 18:10 - 05 Sep 2011    Post subject: Reply with quote
Vincent wrote:
Aye, and the one I'm thinking of with the Gold cases is the 1100 I think Embarassed
I reckon you're actually thinking of the CB1100R, which had a similar fairing, but not much else in common:
https://img691.imageshack.us/img691/4629/1100ry.jpg
That's an 1100RB with no fairing lowers, later bikes had a full fairing and they are all rare and expensive (there would also be one in my lottery winning garage).
This is a 900FC, showing the later wheels that were mentioned further up and replaced the reverse ComStars that were fitted to earlier bikes:
https://img16.imageshack.us/img16/5548/900fc.jpg
This was briefly replaced by the CB1100F, which at first glance looks much the same.
The last post was made 15 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.21 - MySQL Queries: 14 - Page Size: 65.52 Kb
