speedfight 2 transmission oil
Falcon_uk
PostPosted: 08:22 - 09 Sep 2011    Post subject: speedfight 2 transmission oil Reply with quote
Hi all , My speedfight 2 has only one plug at the rear of the transmission and this is to fill , anyone know how to drain the oil from the box
Many Thanks
at106
PostPosted: 19:55 - 09 Sep 2011    Post subject: Reply with quote
The drain plug has been removed because it should never need changing. But you can remove the transmission cover. Then remove the belt. And you can loosen the transmission bolts and the oil will drain out. The reason i say to remove the belt is if you get oil on it it will slip.
The last post was made 15 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.73 - MySQL Queries: 14 - Page Size: 30.42 Kb
