honda cg 125 brake problems
markrolls88
PostPosted: 11:38 - 10 Sep 2011    Post subject: honda cg 125 brake problems Reply with quote
i have a honda cg 125 02 model it has a drum brake when i push down on the brake pedal the main stand moves right and sometimes when im riding along there is no feel to the brake the suddenly it clicks and locks brakes really hard sometimes locks up has anyone else had this problem and knows a solution or and help would be apprieciated
sparky
cb1rocket
PostPosted: 20:44 - 10 Sep 2011    Post subject: Reply with quote
the mainstand shaft has probably seized up inside the stand and now the stand rotates on the frame holes. These holes get bigger over time and causes the stand to wobble all over the place.
Also check the torque arm to the rear brake back plate is on properly. If you can pull it away by hand back and forth then the bolt is worn or the nut needs tightening up
The last post was made 15 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 14 - Page Size: 35.47 Kb
