help me
baldy
PostPosted: 00:38 - 06 Mar 2004    Post subject: help me Reply with quote
Please help i have just boaught a 2001 NSR125r and it seems to be making some strange noises. When it starts it has a crunching sound to it like the bearings have gone but it is coming from the rc valve area. Please help i don't want to break my new bike Question
PostPosted: 16:31 - 06 Mar 2004    Post subject: Reply with quote
Is the noise just when you start it, just when you turn the ignition on or all the time when the engine is running?
baldy
PostPosted: 00:35 - 08 Mar 2004    Post subject: Reply with quote
the noise is only when the bike is on the tickover
PostPosted: 10:56 - 08 Mar 2004    Post subject: Reply with quote
The power valve does not move (from memory) until quite a way past idle. So if the noise is only there at idle then it is probably not the power valve. However I have seen one of these fail. They are not easy to check without pulling a fair amount to pieces. Unless you have some experience I would hesitate to say for you to start to pull the power valve apart.
In the same rough area you have the water pump and the oil pump. The oil pumps rarely go badly wrong on 2 strokes, but the water pump can. If the water pump fails is is likely that it would leak water, and the main place it would leak would be into the clutch casing (I think). As such check for any water leaks and also check the gearbox oil level (there is a small window to view the gearbox oil level). If the level has gone up from water contamination then the gearbox oil is likely to look like mayonaise.
Also in the same area is the exhaust gasket. If this is blowing then it would make a fairly nasty noise, but not like things being crunched together.
ProXimaCore
Dougal
PostPosted: 12:52 - 08 Mar 2004    Post subject: Reply with quote
Yesterday after a long ride on the bike I stopped off to get petrol and when I started up the bike again it made a crunch noise only when the engine fired up. Then it was fine. Turned it off again and tried it once more. It happened again. I haven't had the chance to check it again today. That was the first time that's ever happened. Should I be worried?
Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing Sad
PostPosted: 12:55 - 08 Mar 2004    Post subject: Reply with quote
Where did the sound come from on the bike?
Generally, strange noises are a bad thing. Cos they are things like your gearbox making them. Crying or Very sad
McJamweasel
BCF Junkie
Yes. Be very worried.
The sky is about to fall down onto your head.
And small frogs will eat your toes.
That goes for everyone else too.
ProXimaCore
Dougal
PostPosted: 12:58 - 08 Mar 2004    Post subject: Reply with quote
Hard to tell as I had my lid on at the time. I can check closer tonight but it sounded like it came from the engine area. It's never happened before and I'm kind of hoping I've not buggered it as I was ripping the arse out of the thing for about 2 hours straight prior to this happening... Confused
McJamweasel
BCF Junkie
PostPosted: 13:02 - 08 Mar 2004    Post subject: Reply with quote
Does it feel like its now down on power at all?
ProXimaCore
Dougal
PostPosted: 13:08 - 08 Mar 2004    Post subject: Reply with quote
No it was actually running incredibly well. As good as ever. I only rode it for about 15 minutes more after I first heard the noise.
McJamweasel
BCF Junkie
PostPosted: 13:11 - 08 Mar 2004    Post subject: Reply with quote
Is the chain tension right and is it properly lubed?
ProXimaCore
Dougal
PostPosted: 13:14 - 08 Mar 2004    Post subject: Reply with quote
Haven't checked tension or lubed it since I got new sprockets and chain fitted last week. I'll make sure it's ok though.
McJamweasel
BCF Junkie
PostPosted: 13:17 - 08 Mar 2004    Post subject: Reply with quote
Actually - I just read the post again. Its unlikely to be that (although check it anyway). It might be worth you whipping the starter motor off and greasing that up.
How long is it since the piston/rings have been changed?
ProXimaCore
Dougal
PostPosted: 13:21 - 08 Mar 2004    Post subject: Reply with quote
Got them changed last august. 2000 miles ago. I've always warmed up the bike properly and generally looked after it since having it done. It's just been serviced last week aswell when I got the chain and sprockets. So it should be in good condition. Help appreciated BTW!
dainesefreak
PostPosted: 15:59 - 08 Mar 2004    Post subject: Reply with quote
It's always a bad thing when the bike seems to be running really well, then starts making noises.
Sounds silly but have you checked the oil levels?
ProXimaCore
Dougal
PostPosted: 16:03 - 08 Mar 2004    Post subject: Reply with quote
Not in the last week. That would have been something they would have done at the service I'd imagine. Wouldn't suprise me if they've messed it up though. I better check it out.
baldy
PostPosted: 23:32 - 08 Mar 2004    Post subject: Reply with quote
Thanks kickstart. Helped me find out what it could be. Still not solved the problem BUT i think it must be the water pump because it seems to be leaking water and oil but i cant seem to find out where it is coming from. I have just removed the water pump thingy (just the cover and the fan thing) and started it up for a few moments which is a bit silly i know but i needed to know what the problem was. the rattling seem to not be as bad. If this is the problem could you please send me some info and maybe some diagrams on how to remove or fix this. Any help would be good as i am not exactly bright when it comes to watercooled engines. Thumbs Up Thumbs Up Thumbs Up
PostPosted: 00:19 - 09 Mar 2004    Post subject: Reply with quote
The NSR manual is around for download. Think Scotty or Ste might have it uploaded.
baldy
PostPosted: 00:58 - 09 Mar 2004    Post subject: Reply with quote
The links on their sites are not working. Anyone know anywhere else Question
The last post was made 21 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.1 - MySQL Queries: 13 - Page Size: 106.27 Kb
