immobiliser bypass
dave36
PostPosted: 07:49 - 18 Sep 2011    Post subject: immobiliser bypass Reply with quote
have a 2005 peugeot jetforce 50
lost the red key , have no spark, the immobiliser light staying on does anyone know a sure way to bypass immobiliser
PostPosted: 08:59 - 18 Sep 2011    Post subject: Reply with quote
Simples, there are two options and the first one doesn't even get your hands dirty:
1) Contact the manufacturer (pugeot if it's factory fitted, the maker of the immobaliser if it's not) and get another key with the correct coded chip in it. They will probably want to see some ID and the registration document.
OR
2) Rewire the whole ignition system from scratch.
If it was easy, there would be no point in having an immobaliser.
at106
PostPosted: 09:08 - 18 Sep 2011    Post subject: Reply with quote
Or you could spend about £120 on a bypass unit. But i would try getting a new key first.
PostPosted: 09:40 - 18 Sep 2011    Post subject: Re: immobiliser bypass Reply with quote
Yes.
dave36
PostPosted: 09:42 - 18 Sep 2011    Post subject: bypass Reply with quote
superglue nows thats cools why didn,t i think of that Rolling Eyes do them bypass units work.. will try dealer
Redoko
PostPosted: 10:54 - 18 Sep 2011    Post subject: Reply with quote
You could also try not stealing it.
dave36
PostPosted: 19:33 - 18 Sep 2011    Post subject: bypass Reply with quote
ye should have asked him for red key before i ran off with it the weight of the bloody thing Razz
dave36
PostPosted: 04:50 - 29 Sep 2011    Post subject: bypass Reply with quote
where would i get a bypass unit, the ones on ebay are for speedfights can,t find any for the jetforce
at106
PostPosted: 16:15 - 29 Sep 2011    Post subject: Re: bypass Reply with quote
I think they both use the same system but im not 100% sure. Do you know which immobiliser is fitted you your scooter? Take a look at this https://www.ebay.co.uk/itm/Peugeot-Speedfight-CDi-Immobiliser-Bypass-Gadget-Great-/170700401859?pt=UK_Motorcycle_Parts&hash=item27be896cc3
dave36
PostPosted: 17:28 - 29 Sep 2011    Post subject: immobiliser Reply with quote
same as 2nd one i asked him would it fit said no
at106
PostPosted: 17:33 - 29 Sep 2011    Post subject: Re: immobiliser Reply with quote
Do you know what immobiliser you have?
dave36
PostPosted: 17:38 - 29 Sep 2011    Post subject: immobiliser Reply with quote
same as 2nd one in pic with 2 plug inserts.. numbers on it : IMM006.02
136 03
12V=
at106
PostPosted: 17:54 - 29 Sep 2011    Post subject: Re: immobiliser Reply with quote
136 03
12V=
That bypass should work, i also found this guide https://www.stenberg.dk/ACE400.htm
dave36
PostPosted: 18:51 - 29 Sep 2011    Post subject: immobiliser Reply with quote
thanks for that good read.. think i,ll give that ebay bypass ago..can,t seem to find anything else
at106
PostPosted: 18:58 - 29 Sep 2011    Post subject: Re: immobiliser Reply with quote
If it doesnt work under distance selling regs i think you should be able to return it.
dave36
PostPosted: 04:50 - 20 Oct 2011    Post subject: immobiliser Reply with quote
bypass unit arrived all different wires on it don,t think its going to fit
0ddball
PostPosted: 05:36 - 20 Oct 2011    Post subject: Reply with quote
How much did the dealer quote you for a new red key?
ZXR750L
dave36
PostPosted: 16:44 - 20 Oct 2011    Post subject: immobiliser Reply with quote
well it didn,t work back to square one.. new key 120 bit much i thought..
dave36
PostPosted: 17:53 - 04 Feb 2012    Post subject: jetforce problem Reply with quote
just got another bypasss unit that plugs straight into loom where old immobilizer was still no spark any suggestions
P.
PostPosted: 17:55 - 04 Feb 2012    Post subject: Re: jetforce problem Reply with quote
Dealer.
That is about it Laughing
at106
PostPosted: 18:21 - 04 Feb 2012    Post subject: Re: jetforce problem Reply with quote
Which one did you get?
dave36
PostPosted: 21:08 - 04 Feb 2012    Post subject: jetforce problem Reply with quote
CD 10003
CHIPKEY II
CODE ACI100.01
at106
PostPosted: 21:18 - 04 Feb 2012    Post subject: Reply with quote
If originally you had the AEC400 immobiliser then the one you have purchased wont fit as its designed to bypass ACI100 immobilisers.
dave36
PostPosted: 09:01 - 05 Feb 2012    Post subject: jetforce problem Reply with quote
how do i tell the difference, tried to put up pics but can,t
The last post was made 13 years, 89 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.24 - MySQL Queries: 16 - Page Size: 129.63 Kb
