| Mark65 |
 Mark65 World Chat Champion
| timR6 |
 timR6 Two Stroke Sniffer
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 15:54 - 24 Feb 2011 Post subject: |
| timR6 |
 Posted: 16:02 - 24 Feb 2011 Post subject: |
| Scotsman37 |
| Bezzer |
 Bezzer World Chat Champion
| yen_powell |
 yen_powell World Chat Champion
| cb1rocket |
 cb1rocket World Chat Champion
| binge |
 binge Emo Kiddy
| Mark65 |
| cb1rocket |
 Posted: 21:00 - 24 Feb 2011 Post subject: |
| cb1rocket |
| yen_powell |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Mark65 |
| Ichy |
 Ichy World Chat Champion
 Posted: 08:41 - 25 Feb 2011 Post subject: |
Not hard to work out.
E = Effective length of extension - measured along the centerline of the torque wrench.
L = Lever length of the wrench - center of grip to center of drive.
T(W)=Torque set or read on wrench
T(E) = Actual torque required
T(W) = T(E)* L/(L+E)
So if you want to set the fixing to 12Nm, the normal length of the torque wrench is 100mm from the grip to the drive and your extension is 40mm from the drive to the center of the fixing then
Reading = 12 * 100/(100*40)
So the reading should be 8.57Nm.
Another way around it is to set the crows foot at 90 degrees to the drive. Your not changing the effective length of the lever significantly enough to affect the reading. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Mark65 |
| Bezzer |
| neil. |
 neil. World Chat Champion
 Posted: 20:14 - 25 Feb 2011 Post subject: |
Yamaha do sell the specific torque wrench bit but it is around £70 which is a rip off. The torque settings Yamaha quote for adjusting the headset are with that extension at a 90 degree angle to the left. I do have one though . Can post it to you if you want to borrow it for this? Also I've never regreased my head bearings, I was going to but a mechanic that I know well and trust told me not to disturb them unless they needed to be replaced/adjusted. 36'000 miles/5 years so they've missed 2 'regreases' and they are still pretty much okay with a very small notch which is hard to detect but the bike passed MOT fine, no advisory for it. I have had to adjust them a few times as there was some play that developed. The Yamaha C spanner end did make the job really easy with the torque wrench and the steering feels spot on. I do have a set of tapered rollers standing by, just haven't got round to doing them yet.  |
| Mark65 |
 Posted: 21:08 - 25 Feb 2011 Post subject: |
neil.
Many thanks for the offer, but if yours has gone that long without needing a service i will take the advice and leave it lol ,ine only has 13265 atm , i thought it was something that needed doing, and £70 for what is basically a crows foot , ouch thats scary, i do like trying to make things so if you know the diameter of the par tor maybe post a piccy of the part with a ruler next to it i may buy a rigid c spanner of the bay and have a go along with the socket, the choice is sit with wife or faff about in the garage if all else fails i will take you up on the offer if it needs adjusting, albiet as you have bought it i would gladly rent it .
Thanks
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| neil. |
| Mark65 |
There is a gap of 222 days between these two posts... |
| sparkywilliam... |
 sparkywilliam... Scooby Slapper
| kramdra |
 kramdra World Chat Champion
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 00:23 - 08 Oct 2011 Post subject: |
I did mine myself, it isn't technically difficult, its just that it requires alot of force to get the old races out/off and the new ones in/on.
I took my yoke and stem to a local garage and had them remove the old lower race and refit the new one using their "special tool" (ie. an old fork stanchion).
I knocked the old races out of the frame using a hammer and drift, and pressed the new ones in using a wooden mallet to get them in until they were flush with the frame, then merely tightening them up to draw them the rest of the way in. I did spend about £30 on the "special" Honda socket though. Did make it way quicker than using a hammer and punch to tighten them up.
Tip: Leave the outer races (I think its the outer ones, the ones that go into the frame) in the freezer overnight.
Tip2: Don't touch -18c metal races with moist hands  ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
The last post was made 14 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
