| EazyDuz |
 EazyDuz World Chat Champion
| Kickstart |
 Kickstart The Oracle
| EazyDuz |
| Kickstart |
 Posted: 14:21 - 12 Oct 2011 Post subject: |
In which case check other things VERY carefully. Such as the chassis number (should be stamped on the head stock, although probably on a rivet on tin plate as well - in which case check all match). Not sure if Suzuki have stickers under the seat giving the year of the bike. Also if the original tyres are on (OK, unlikely by now) check for any date marks on those, same for the rubber brake lines.
While an engine change isn't that unusual and nor is swapping indicators, swapping both to be from a bike a couple of years earlier is ; with indicators if swapped they normally get changed for cheap and nasty mini ones.
As such I would be concerned that the bike is a nicked 2003 one that someone has passed on with the identity of a different legitimate bike.
| EazyDuz |
| Kickstart |
 Posted: 14:41 - 12 Oct 2011 Post subject: |
HPI can only check the details they are given, and if the identity is from a legitimate bike it is those details they check rather than a bikes real identity. Some theives might just transfer over the (pretty meaningless) tin plate, while some might restamp the actual frame, or just destroy the chassis number on the actual frame.
Used to be one of the major reasons to be wary of write offs wasn't for the damage they had sustained but that the identity of the write off was being used on a stolen bike. This way if an HPI type check was done it might come back as a write off but people would buy it as it looked immaculate (the actual written off bike having long ago landed up crushed).
| EazyDuz |
| Kickstart |
 Posted: 14:47 - 12 Oct 2011 Post subject: |
Sorry, but panic.
Unrelated bits matching an older bike just sets the alarm bells ringing for me. I really do hope that there is nothing actually dubious. Hence check very carefully, and with chassis and engine numbers check for any sign that that have been obliterated or modified.
Legally if it is a ringer then the bike isn't yours (as it wasn't the previous owners to sell to you).
| EazyDuz |
| Kickstart |
| EazyDuz |
The last post was made 14 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
