lifan 125j city x electrical problem
mgs41987
PostPosted: 14:11 - 15 Oct 2011    Post subject: lifan 125j city x electrical problem Reply with quote
hi, first post so bear with me lol, got a lifan 125 j and i have hunted the forum the web for the haynes chinese 125cc workshop manual and always drawn a blank but i know for fact in the back it has my wiring diagram and i really need it as i have found a wire in my loom pink and green with some form of fuse housing snapped off i have had a thorough look for the other end of it but not be seen, ever since i have found that wire the engine has become unreliable kill switch does not work and if i turn the egnition off the bike continues to run, hense i need the diagram to see if the colours change like alot of them do please help lol thankyou
spyuggy
PostPosted: 19:06 - 15 Oct 2011    Post subject: Reply with quote
One thing you can try is to remove the kill switch and check the colour of the wires, if one matches, then you can join them up together, after you have traced where the rest of the wire has gone.
It sounds like it in the main feed to your kill switch, with having a fuse attached, maybe someone has done a bodge on it.
Treat each day as if it was your last, because one day you will be right.
mgs41987
PostPosted: 19:35 - 15 Oct 2011    Post subject: Reply with quote
i have check the kill switch but i have a suspicion that its coming from the cdi but its coming up the loom into the head no spare sockets nothing one wire is earth other is pink and the loom is untampered with in origion trunkin i need to find the wiring diagrams only way forward thankyuou for your response
The last post was made 14 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 14 - Page Size: 35.16 Kb
