Bandit 400 fork changes
alun111
PostPosted: 08:01 - 17 Oct 2011    Post subject: Bandit 400 fork changes Reply with quote
Hi,
I appreciate any help you can give on this matter...
I need a new set of forks for my 1993 bandit 400vv as the left fork leaks. I've replaced the seals and they blow after no time. Last time I changed them I did all the bushes too. The stanchion's surface appears to be fine, but i suspect the stanchion itself must be bent.
I have sourced a set of used forks, but they are approximately 50mm shorter than mine. They are off a 1991 bandit 400. I thought at first that maybe the model they came off had the normal kind of bars, but it doesn't - It has clip-ons like mine does. I thought the clip-ons on my model would explain the longer stanchions (for the clip-ons to go around) but obviously it doesn't.
My question is would using forks that are 50mm shorter than mine screw up the handling? I know it would make it turn in faster but could it do it to the extent of making the front end twitchy/unstable?
I don't know what chassis changes (if any) the bandit 400 had between 1991 and 1993 so I don't know if the steering geometry changed in any other ways.
Thanks!
The last post was made 14 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 14 - Page Size: 28.1 Kb
