| SpannerMonkey |
 SpannerMonkey World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 19:01 - 01 Nov 2011 Post subject: |
Lots of carb fiddling awaits you
Changing the needle position to get it perfect/changing jets. I'd start 10 above normal and work your way through that. |
| SpannerMonkey |
| serlant |
 serlant Brolly Dolly
| SpannerMonkey |
| pepperami |
 pepperami Super Spammer
 Posted: 19:27 - 01 Nov 2011 Post subject: |
Are you using the standard air-box?
Possibly? maybe? = bigger bore + bigger carb = more suck = standard air-box & standard airfilter not able to deliver??.
Are you using an aftermarket bolt on air filter like a K&N? = possibly? maybe? = new airfilter allowing to much air = poor detination = wet plug/partially burnt fuel ?
Larger inlet manifold playing havoc with the "Venturi effect" ????
just an idea/my  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| SpannerMonkey |
| pepperami |
 Posted: 20:17 - 01 Nov 2011 Post subject: |
????? hmmm? is the exspansion pipe you have on there so open that you`re not getting any back pressure?.
In the bad old days of me trying to wring extra power out of small strokers (YB 100`s, A 100`s, ) I seem to remember that putting on a spannie sometimes used to move the power further up the rev range, depending where the spannie came from ie was it the right one for that bike?
I know it might sound like a silly question ? but is the slide going all the way up when you twist the throttle?.
Are the reeds to stiff and not letting the carb operate properly?
can you mount the carb without putting the reeds in?, just to see if that gives an improvement?
Just a thought  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| SpannerMonkey |
| pepperami |
 Posted: 20:36 - 01 Nov 2011 Post subject: |
I`m just going through the sort of things I would look at if it was my bike.
How many ports on the old barrel?
7 on the new one .
I`m guessing that when you got the the new 65cc kit, it included matching piston and rings?
Is it points ignition? and now you have a new bore/stroke, do you need to adjust your timing ?
Crickey! i`m running out of ideas  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| SpannerMonkey |
| pepperami |
 Posted: 21:07 - 01 Nov 2011 Post subject: |
Now you have a high compression head, do you need to change your plug for one with a different reach?
now I`m stumped  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| SpannerMonkey |
| hmmmnz |
 hmmmnz Super Spammer
| Johnser |
 Johnser Renault 5 Driver
| dougon2wheels |
 dougon2wheels Nitrous Nuisance
| SpannerMonkey |
| Johnser |
The last post was made 14 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
