Aerox 50 problem please help
Diesel
PostPosted: 16:21 - 23 Oct 2011    Post subject: Aerox 50 problem please help Reply with quote
Hi there, Help is much appreciated
i have a 54 aerox but it has an 07 engine in the bike, i have put a new cylinder and piston in recently and changed all liquids in the bike from all oils petrol and coolents etc. this bike has been well maintained and i have serviced and look after it. i have a problem, i rode it to my sixth form and it was running fine but 7 hours later and got it read to warm up but it wont start, it was tickening over and i could hear it trying to start but it just wasnt starting. so when i finally got home after pushing it about 7 mile in a suit, i stripped all plastics and checked the spark plug there was plenty of oil but no petrol. so i put a bit of petrol on the spark plug and it started but then conked out, so this then lead me to believe there is a block in the carb,and its not letting petrol in. so i took the carb of and there was loads of coolant in the carb dripping out of it, and there was loads. the coolant has come from the two pipes from the cylinder head which connect to the carb. i have checked the engine oil that looks fine soo thinking it might not be head gasket but now im not sure what it is. any help please
sorry about the essay but i thought the more information the better Smile
spyuggy
PostPosted: 18:22 - 23 Oct 2011    Post subject: Reply with quote
It sounds like a burst water pipe to me, as the carb was filled with coolant.
Give it a good clean out and check your pipes and joints, especially around the carb.
Treat each day as if it was your last, because one day you will be right.
SpannerMonkey
PostPosted: 20:37 - 23 Oct 2011    Post subject: Reply with quote
as far as I remember there should be NO lines going from carb to cylinder head... I think there is only vacuum line and fuel... possibly and oil line too...
My bike? A YX140 powered one-off Monkey Bike, something a little different!
The last post was made 14 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 14 - Page Size: 35.56 Kb
