Suzuki Bergman 400 - 33BHP?
Okeydokey
PostPosted: 00:01 - 24 Oct 2011    Post subject: Suzuki Bergman 400 - 33BHP? Reply with quote
I've seen a few opinions on whether this is ok! for the first two years without restriction but I cant find a definitive answer... does anyone know?
Thanks
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruitsalad!
YB100 v. Ford Sierra (1982 I came 2nd place) Honda H100S (Currently 0 - 0) CX500 Cafe project (me 1 - wife 0.... maybe!)
Efes123
PostPosted: 07:31 - 24 Oct 2011    Post subject: Reply with quote
I believe it has 33.5 bhp so technically no. But, I can't see the rossers doing you for being 0.5 over the bhp. However as the actual restriction is 25Kw I believe the 33 bhp is an approximate ruling.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
PostPosted: 08:09 - 24 Oct 2011    Post subject: Reply with quote
The law is 25kW, probably at the flywheel crankshaft. However, that's impossible to measure without taking the engine apart, so the number is calculated based on power at the rear wheel * VOODOOMATHS.
I think the chance of you being successfully prosecuted is somewhere between zero and half of zero.
However, your insurer may want to see some evidence that it's <=25kW (or may not, my GPZ 305 claimed 25.5kW as new and I haven't been asked). I'm sure your friendly local dyno place can use whatever VOODOOMATHS required to arrive at that figure if you tell them the number that you want to see.
PostPosted: 08:13 - 24 Oct 2011    Post subject: Reply with quote
33bhp is the limit.
They could prosecute for 33.0000001bhp.
No approximation required. 33bhp or less is the law.
PostPosted: 08:46 - 24 Oct 2011    Post subject: Reply with quote
Big_Ham wrote:
33bhp is the limit.
The Motor Vehicles (Driving Licences) Regulations 1996
and The Motor Vehicles (Driving Licences) Regulations 1999
MV(DL)R wrote:
“large motor bicycle” means—(a)in the case of a motor bicycle without a side-car, a bicycle the engine of which has a maximum net power output exceeding 25 kilowatts or which has a power to weight ratio exceeding 0.16 kilowatts per kilogram, or
25 kW = 33.52554647 (b)hp.
The point of contention is more likely to be "engine [...] maximum net power output". A reasonable interpretation is the power measured at the crankshaft, but that requires a bench test. However, if the power measured anywhere after the crankshaft exceeds 25 kW, you're potentially in trouble, since the "maximum net power" can only be higher.
PostPosted: 10:32 - 24 Oct 2011    Post subject: Reply with quote
I think the main query is why on earth would you ride a burgervan?
You should be fine with no restriction on that, I doubt you'll ever get pulled anyway Thumbs Up
PostPosted: 12:58 - 24 Oct 2011    Post subject: Reply with quote
Because God - Allah - loves wondrous diversity?
Viewed as a means of transport I think they make a lot of sense. Yes, I'm scoot-curious. Shifty
PostPosted: 13:16 - 24 Oct 2011    Post subject: Reply with quote
Only ever ridden a ped once, hated it. Would try a burgervan, but lack of gears would be a pain for me.. I like gears. Laughing
Cadbury
PostPosted: 14:02 - 24 Oct 2011    Post subject: Reply with quote
They do a 650 'executive' model that has an electric tiptronic style gearbox on it. Basically an up and down button on the left handlebar. From what I have read though most people just leave it in full auto mode.
fatpies
PostPosted: 14:08 - 24 Oct 2011    Post subject: Reply with quote
The power to weight ratio..
I remember ages ago some Honda 125cc cruiser was so incredibly heavy even though the engine made a bit more than the 12.5bhp it was allowed for learners.
Is my memory playing tricks on me or did this actually exist? I mean what would stop you from adding a shed load of weight to a bike just slightly over?
PostPosted: 14:39 - 24 Oct 2011    Post subject: Reply with quote
The Burgman 400 has been described as the "escort van of the bike world". I fancy one myself.
jimbothe
PostPosted: 16:53 - 24 Oct 2011    Post subject: Reply with quote
I fancy one myself.
Must admit I've had a gander as well. Shifty
They are so cheap! Look like a bargain to me.
There is one just up the road from me and at a pretty good price for a 02 plate
https://www.ebay.co.uk/itm/Suzuki-Burgman-400-K2-/150679239911?pt=UK_Motorcycles&hash=item23152ebce7
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
PostPosted: 18:02 - 24 Oct 2011    Post subject: Reply with quote
Dunno. At the moment, the categories are:
Arrow A1 / "learner": <= 125cc and <= 11kW. No weight / power to weight limits yet, but the 3rd Directive will define an A1 category with a maximum 0.1 kW/kg limit.
Arrow A2 / "standard": <= 25kW and 0.16 kW/kg.
Arrow A / "large" = anything else.
Nothing really, as long as its a part of the bike and not just slung on it.
MV(DL)R 1999 wrote:
“power to weight ratio”, in relation to a motor bicycle, means the ratio of the maximum net power output of the engine of the vehicle to its weight (including the weight of any side-car) with—
(a) a full supply of fuel in the tank,
(b) an adequate supply of other liquids needed for its propulsion, and
(c) no load other than its normal equipment, including loose tools;
Okeydokey
PostPosted: 18:19 - 24 Oct 2011    Post subject: Reply with quote
All the above is good enough for me and my cavalier approach to life, disrespect for authority, and very shallow pockets.
Many thanks all!
Burgervan it is then Laughing
The last post was made 14 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 87.45 Kb
