 John World Chat Champion
 Posted: 17:29 - 14 Mar 2004 Post subject: Going to see a bike, what should I check? |
OK, having a look at a VFR tommorrow morning, thanks G and Maurice for the help so far.
This is my list so far; (below)
Anything else I need to check? I bet i've missed something. Thanks
V5 -
Engine Number
Frame Number
Crash Damage?
Radiator - any dents? 2 radiators to check
Clip Ons- (bars to put hands on, clip onto forks, check straightness)
Oil Sump Bolt, Drilled? (right hand engine casing) drilled = race bike
Rearsets (footpegs, check for straigtness, if not plastic probably replaced)
Forks, are they straight, do they have any notches?
Wheels, dings in rim? fixable cheaply
Engine - Is it straight?
Fairing brackets - Straight?
Wear?
Brakes, do they stick?
Chain and sprokets, corrosion or damage?
Swingarm - any play is expensive, non adjustable
Fan - Check it works!
Regulator/Rectifier - was a heal point on early models. If the unit itself or its wiring are
running hot, or if the battery is overcharging (i.e. more than 15.5V@5,000rpm) (£50) Lights
should brighten wheb reved
Shock, does it bounce back right? check leakage and the linkages for any binding or
creaking.
Lights / Horn / Fuel Gauge / Temp Gauge - Do they all work?
Clocks, are they reading correctly, is the mileage straight?
Notes
cam drive gears always whine
Restriction - have a look at the ignition unit, just ahead of the rear lights under the seat
hump, and see if it has a small black box plugged in in series with it. ____________________ TT600 neeeeeeeeeeeeeeeeeeowwww! |
 Ste Not Work Safe
 Posted: 17:41 - 14 Mar 2004 Post subject: |
With the forks, check that they compess smoothly, and check it after you test ride for any leaking oil.
Check the wheel bearings and head bearings.
Oh yeah, check the gearbox.  |
 EuropeanNC30R... Gay Hairdresser
 Posted: 17:48 - 14 Mar 2004 Post subject: |
The bike can be de-restricted in a number of places, including a plug-in box on the cdi, a plug-in behind the clocks, an mph-kph converter or by bending the tab within the clocks. You can check for everything apart from the tab in the clocks, to test that you'll need to get past 112mph on the test ride Though saying that, mine wasn't bent far enough back so it kicks in at an indicated 130 . |
 mr.z World Chat Champion
If you haven't already https://www.hpicheck.com/
Also sounds silly but, check the finish, if its got pitted forks and rusty underside then its obviously not been looked after, if the outside is mess then chances are so is the inside... |
 1cyl World Chat Champion
 Posted: 19:52 - 14 Mar 2004 Post subject: |
Check around for any rounded off nuts, especially the oil drain one. one of these can be more trouble than a pack of hungry gorillas.
What ever you find wrong use as an excuse to knock him down a couple of quid, when i bought my Z i knocked the guy from 375 200 because it had no chain guard and and the rev counter was bust, rofl! ____________________ Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable |
