| mgh0 |
 mgh0 Scooby Slapper
 Posted: 20:16 - 27 Oct 2011 Post subject: noob alert: adjusting throttle cables |
I recently took off the carb on my CG125, it all went back together however the step in the haynes manual where it says to adjust the throttle cable gives little clue to the uninitiated as to how to go about this...
Can anyone give me some tips?
The twist grip operates the throttle and engages the cam but on release the throttle stays open (engine off, fuel tap off), rotating the twist grip closed does shut it.
Obviously unsafe so how do I make it all nice and tight again?
Cheers and virtual beers in advance  |
| Suzuki reece |
 Suzuki reece Derestricted Danger
 Posted: 20:22 - 27 Oct 2011 Post subject: |
you need to take the slider from the carb and make sure the spring is all in tact if it is try stretching the spring it should be touching the bottom of the slider and the top of the slider casing  ____________________ :)reece(: |
| mgh0 |
 mgh0 Scooby Slapper
 Posted: 00:02 - 28 Oct 2011 Post subject: |
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:33 - 28 Oct 2011 Post subject: |
What I suspect you may have done is put the slide back in the carb the wrong way round.
Unscrew the cap on top of the throttle, withdraw the slide and needle, and re-insert it with the groove in the slide facing the idle screw. ____________________ Biking is 1/20th as dangerous as horse riding.
| mgh0 |
 mgh0 Scooby Slapper
| mgh0 |
 mgh0 Scooby Slapper
| mgh0 |
 mgh0 Scooby Slapper
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:38 - 28 Oct 2011 Post subject: |
I can't think of anything that would cause that other than the throttle slide being stuck open.
I'd suggest double checking that the slide is in the right way around.
Pop out the slide and needle and have a look at it. There's an angled indentation on the slide. This must be oriented facing the idle screw, so that the screw sits in the indentation (and screwing it in and out limits how much the slide can close).
If it's oriented any other way, the slide will simply sit on top of the idle screw and be held open.
This is a lot simpler to figure out with your hands on the carb than it is to explain with a keyboard.  ____________________ Biking is 1/20th as dangerous as horse riding.
| mgh0 |
 mgh0 Scooby Slapper
 Posted: 12:03 - 01 Nov 2011 Post subject: |
You were right, slide was out of alignment.
Bike started, idled, stopped, did not start again  |
| The Artist |
 The Artist Super Spammer
The last post was made 14 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
