| RickTaff |
 RickTaff Nitrous Nuisance
| chris-red |
| RickTaff |
| Ste |
 Ste Not Work Safe
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 16:34 - 24 Sep 2018 Post subject: |
The common rule says split links are only for engines of displacements upto 500cc (roughly 50 Nm of torque). Riveting is easy, quick and safe, if done right and you do not need any special tools for that. 600cc is roughly 60 Nm (modern 4 cylinder bikes even close to 70 Nm), and although 10 Nm seems like nothing, the difference is not negligible.
Rivet links tend to be a part of the chain set that you buy. Or at least the last time I bought a brand new chain the rivet link was there. I also bought a split link chain and there as well was a split link and the clip.
X-ring (no rubber rings) vs O-ring (rubber rings). X-ring is recommended for riding in mud and dust (track bikes use them as well), it's more durable for that, however the replacement interval is much shorter. O-ring chains are the high tech stuff here, that's meant to be used on the road, very long life if properly maintained, also quite quieter.
EDIT: I messed up a bit, but nothing important, in this case anyway. X-ring also has rubber rings there, I meant to say chains with no rubber rings (used in MX and racetracks).
https://www.did-coltd.com/english/products/images/wr/g001.gif
Feck, chains got quite complicated in the past few years. O-ring, X-ring, Square-ring...
https://www.didchain.com/images/xRingStreet2.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| RickTaff |
 Posted: 16:47 - 24 Sep 2018 Post subject: |
| RhynoCZ wrote: | The common rule says split links are only for engines of displacements upto 500cc (roughly 50 Nm of torque). Riveting is easy, quick and safe, if done right and you do not need any special tools for that. 600cc is roughly 60 Nm (modern 4 cylinder bikes even close to 70 Nm), and although 10 Nm seems like nothing, the difference is not negligible.
X-ring (no rubber rings) vs O-ring (rubber rings). X-ring is recommended for riding in mud and dust (track bikes use them as well), it's more durable for that, however the replacement interval is much shorter. O-ring chains are the high tech stuff here, that's meant to be used on the road, very long life if properly maintained, also quite quieter. |
The chain i bought had the split link included, but garages round here tell me i can still rivet a standard chain, whether it is O ring, X ring or neither. I just need to buy a single rivet master link, or whatever you'd call it. Found a few pretty cheap, like this one
https://www.ebay.co.uk/itm/DID-525-VX2-VXGB-Gold-Rivet-Type-Connecting-Master-Chain-Link/362130030904?epid=4007035113&hash=item5450a1c138:g:TBoAAOSw2xRYmZqx
Or this one?
https://www.ebay.co.uk/itm/525-Ring-Chain-Rivet-Joining-Link-Gold-Motorbike-Universal-Rivet-Drive-Chain/253805635375?hash=item3b17fea72f:g:8c8AAOSwKHBbbA6Q
But that first link would not work on my chain obviously as my chain is your standard heavy duty one. So I am scratching my head at the minute. I am told they can be bought, just finding the buggers |
| RhynoCZ |
 Posted: 16:54 - 24 Sep 2018 Post subject: |
Oh that, yes you may rivet your chain. Instead of that split link (grooves for the clip) you will use the rivet link (smash with a punch and hammer until flat enough).
So you have O-ring chain? Rubber rings on each link? Then buy a rivet link with 4 rubber rings. They should also supply you with a lubricant you use, before you rivet it.
To be honest, I have never really thought about this before. One time I had to rivet my chain, because I was putting the final drive gear ratio back to stock (the previous owner was a joker), so I had to remove some links and I used whatever rivet link they had at my local motorcycle parts shop. The bike did many miles after that, then I sold it and the owner haven't called since, so alright there as well. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Ste |
 Ste Not Work Safe
| Ste |
 Ste Not Work Safe
 Posted: 17:06 - 24 Sep 2018 Post subject: |
Oh and as much as I wouldn't use a split link, if you don't have a rivet link then I'd use the split link whilst waiting to get something better.
The R6 that broke a split link was also used as a race bike and track bike so it hadn't had an easy life. Realistically, you'll be completely fine using a split link especially if it's only to tide you over until you can get your hands on a rivet link.
What bike is it going on? |
| RhynoCZ |
| RickTaff |
| RickTaff |
| RhynoCZ |
| RickTaff |
| RhynoCZ |
 Posted: 17:32 - 24 Sep 2018 Post subject: |
Use the split link that came with the chain.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Ste |
 Ste Not Work Safe
| RickTaff |
| MCN |
 MCN Super Spammer
| Ste |
 Ste Not Work Safe
 Posted: 18:40 - 24 Sep 2018 Post subject: |
n00b.
You're meant to carry spares.
| RhynoCZ |
| MCN |
 MCN Super Spammer
The last post was made 7 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
