Licence categories, possible DVLA fuckup?
PostPosted: 16:33 - 04 Dec 2011    Post subject: Licence categories, possible DVLA fuckup? Reply with quote
Once again I require your assistance, elders of BCF!
I passed my A2 on the 23/11/2010. I then passed Accelerated Access on the 24/11/2011. Sent licence off to the DVLA thinking "this is going to go wrong..."
...And today I get the brown envelope containing my new licence. I open it up to find I have Cat A on the rear of the photocard with a "from" date of 24/11/11. My counterpart shows "A2" under "Entitlement History", valid from the 23/11/10.
I was under the impression I already had an "A" licence and was just removing the restriction code?
I've looked at the following pages for guidance and I believe the DVLA have it wrong, can anyone confirm?
https://www.direct.gov.uk/en/Motoring/LearnerAndNewDrivers/RidingMotorcyclesAndMopeds/DG_4022568
https://www.direct.gov.uk/en/Motoring/DriverLicensing/WhatCanYouDriveAndYourObligations/DG_4022547 - This one especially as there's no "A2" licence code.
Alex A
PostPosted: 17:06 - 04 Dec 2011    Post subject: Reply with quote
What's wrong with it?
You had A2 from the Restricted Test Pass date. Now you have A from the Accellerated Access pass date.
Question
J.M.
PostPosted: 17:08 - 04 Dec 2011    Post subject: Reply with quote
From how I understand it, is as follows:
You've got the A2 license and you've got the A license.
The A2 license is the A license except it has your restriction on it. On your license the A2 license is shown as category A because you do have a full A license (it just has a temporary restriction.)
After your restriction expires it's an A license.
In short, A2 is actually a sub-category of the A license and is not actually a category of its own. This is as suggested here:
Sub-category A2 (standard motorcycle)
A sub-category A2 motorcycle a solo motorcycle between 121 and 125 cc.
So as a best understand it, you did and do have a category A license, but your restriction has now been removed Thumbs Up
https://www.best-motorcycle-information.com/image-files/motorcycle-licence-routes.gif
2004 R1 & 2018 XSR900
PostPosted: 17:10 - 04 Dec 2011    Post subject: Reply with quote
I'm just worried the insurance companies will see that my category A was "only" held from 24/11/11, when in actuality I've had it a year longer. Neutral
Edit: It would appear the information on the DVLA website is there, just not entirely easy to find. I bow to thee, knowledgeable gods of motorcycling, and I will take my stupidity out of your presence. Laughing
blurredman
PostPosted: 17:52 - 04 Dec 2011    Post subject: Reply with quote
That's a point..
When the A2 naturally matures into A, and you send off for a new licence, will you get the A2 pass date back? Or will you get the date on which the A2 has matured into A (ie, two years post)
PostPosted: 18:37 - 04 Dec 2011    Post subject: Reply with quote
A"... is your FULL licence, so you say I've held it for 1 year, even though your A category says like 4 days ago or whatnot Thumbs Up
dodgydog
PostPosted: 18:42 - 04 Dec 2011    Post subject: Reply with quote
Jesus fucking H, I remember when riding around the block was enough, as long as you didn't run the examiner down when he jumped out for the emergency stop, ( it happened ) job's a good un.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
PostPosted: 20:13 - 04 Dec 2011    Post subject: Reply with quote
Blurredman wrote:
That's a point..
I've got mine back with a pass date from the AA, not my original pass date.
PostPosted: 21:27 - 04 Dec 2011    Post subject: Reply with quote
Did you put a covering letter in telling those incompetent twunts not to dick around with your pass date? I seem to recall suggesting that to someone recently, since we know they've been nobbing us over on this issue.
Right, under current legislation A2 is not a license class. It's a category of test bike - and is a local UK definition.
Ignore whatever jizz is currently congealing on the Wikipedia licensing page, I can't mop it up fast enough. The underlying European directive is 91/439/EEC aka the 2nd European Driving License Directive, implemented in the usual gold plated cack handed manner in the UK as The Motor Vehicles (Driving Licences) Regulations 1996.
Please take a moment to read them. Neither document makes any mention of "A2". All (current) European motorcycle licenses are either A1 or A, and all A licences by default limit you to 25kW / 0.16kW/kg for 2 years, although "this requirement as to previous experience may be waived if the candidate is at least 21 years old, subject to the candidate's passing a specific test of skills and behaviour".
There's nothing particularly complex about this. What causes the problem is that in the UK, almost everybody over 21 goes down the DAS route (our local interpretation of that "specific test of skills and behaviour") and so a perfectly standard European A license is considered to be a "kiddy" license and we get all sneery about it and try to give it a different name to distinguish it from a "proper" license.
tl;dr version - I would recommend that you write to the DVLA and tell them that are in error. You obtained your A license, as defined by 91/439/EEC, on 23/11/2010.
If they argue, kick it off up their complaints procedure, citing the relevant directive and law at each stage and noting that you will be happy to drag them into a civil action with the next insurer that tries to chisel a year off of your license duration. You went from a 1 year A license to a 0 year A license after "upgrading" it? I don't think so. They need to change your pass date back to 23/11/2010 and then shut up forever.
PostPosted: 23:39 - 04 Dec 2011    Post subject: Reply with quote
Nope, just handed it over at the test centre after the examiner said errors are "extremely rare"...
As for the rest, that's exactly what I thought, but much better worded!
Rogerborg... Wub
Edit: Written out a letter and included photocopies of my old licence, new licence, pass certificates and copies of the relevant subsections of both pieces of legislation.
Roger, if you're ever around SE London/Kent, I'll buy you enough beer to keep you drunk for a week.
Bomberman
PostPosted: 02:03 - 05 Dec 2011    Post subject: Reply with quote
lol, my examiner said photocopy everything, both sides and keep them very, very safe Very Happy He was err... less than convinced in the admin staff at the DVLA. That said, my license did come back in less than two weeks with an address change, points cleared and a photocard as oppose to the paper license I'd had since '94. Which the original sellotape had failed on Laughing
PostPosted: 14:16 - 05 Dec 2011    Post subject: Reply with quote
The thing to do is make it clear to an insurance company what the case is.
Do it over the phone and when they ask "How long have you held this licence.", tell them "I passed my A2 motorcycle test on: xxxxx and passed my direct access motorcycle test on: yyyyyy.". Let them draw their own inferences from this.
I say this because someone on here recently had their insurance cancelled on the basis that they had arbitrarily decided that "full" licence meant when the restricted period was finished, not from when the full licence was issued. They maintained the figure given for how long a full licence had been held had been misrepresented and cancelled the policy.
Before anyone comes on telling me this is wrong, I agree, it is totally wrong BUT it is also de-facto the case with at least one insurance company. At the end of the day, it's their decision if they want to issue you insurance and on what basis. If you explain things like I described above, you cover your arse.
EazyDuz
PostPosted: 14:29 - 05 Dec 2011    Post subject: Reply with quote
I just got my licence today after doing A2 test, it just says A on the back of the card, then next to it it shows the restriction.
PostPosted: 15:31 - 05 Dec 2011    Post subject: Reply with quote
This makes sense, but it's a ball ache to have to call them, since it gives them an opportunity to nob something else up.
For those of us with an "A<= 25kW" license, it's a laugh and a half trying to find an appropriate category on a web form. Most of the time there's no distinction, so we run the risk of them pulling that "Nuh-huh, you don't have a 'full' license" stunt, even though they didn't provide any option to give that information.
Possibly worse is eBikeInsurance, who actually list "A2" as a license category. I essentially lied to them by selecting that, guessing that's probably what they meant.
It's really not rocket science to list "A (unrestricted)" and "A (<= 25kW)". I can't understand why people who ostensibly do this for a living make it so hard for everyone involved to provide truthful information.
In a way, it'll be a relief when the 3rd Directive kicks in and the categories become unambiguous, although there will be a 2 year period where the old and new schemes run side by side and nobody will know what the chuff they think they mean by an "A2" license.
</Pointless Rant>
PostPosted: 17:47 - 05 Dec 2011    Post subject: Reply with quote
Just called up, the nob on the end of the phone insists that I held an A2 licence previously and that it is correct.
When asked why this licence category doesn't appear on any of the government websites or anywhere in the 2nd EU DL Directive he told me "It's obvious I'm not going to convince you, just put it in writing and we'll tell you why you're wrong".
The fucking cheek of it!
I've held a Cat A licence for a year, I want my fucking licence to show it! Evil or Very Mad
Edit: Supervisor called back, she said she's going to consult the policy department tomorrow, but her guidance document shows am A2 licence. Politely reminded her that A2 is not a licence class and there's no mention of the licence type in any official documents. She once again said she's only going by the advice sheet she has and that she will call back tomorrow. Rolling Eyes
PostPosted: 21:15 - 05 Dec 2011    Post subject: Reply with quote
They really are ignorant, arrogant mongs. The way to "convince" you would be to cite the Directive, Statute or Regulation that defines an "A2 license". Good luck with that.
Well, at least you've got the ball rolling. I'll doubtless be in the same boat the next time I get a license refresh and they knock 2 years off of my "pass" date, so Karma from me for getting stuck in.
0l0dom0l0
PostPosted: 22:41 - 05 Dec 2011    Post subject: Reply with quote
What a load of bollocks.
I've just looked at the back of my licence and I'm currently just over a year into my restriction.
I've got a CATEGORY A entitlement, with the code <=25kw written in the codes box. So, I have exactly the same entitlement as my dad who passed direct access on the same day as me, I just have a code which says I have to restrict the bike blah blah.
A code is something that you must abide by but you still have a full category... for example if you wear glasses you have a code on your licence that says you need to wear glasses. If you then get Laser treatment on your eyes and you are medically enabled to drive without glasses and you send off your licence you haven't then passed your test on the day you got your eyes lasered have you?
Bunch of retards. I was going to send off my licence when my restriction is up to remove the code but I don't think I'll bother now!
PostPosted: 11:09 - 06 Dec 2011    Post subject: Reply with quote
FOI reply:
DVLA Drivers Policy Group wrote:
In accordance with Directive 91/439/EEC, the current motorcycle driving licence categories are A1 and A, with category A covering restricted or unrestricted versions. DVLA does not issue a licence category A2.
See, someone there actually knows what's what. Enjoy! Very Happy
Actually, I can predict what they're going to say when you've carved your way through the layers of disinformation.
Since they do distinguish between "A" and "A <= 25KW" on the plastic card, then in that context they can argue that the dates that they show are technically correct - the best kind of correct - since they say "From" and not "passed" or "obtained".
However, it does screw us over since insurers will almost certainly want to go by the (later) date shown on the license rather than the (earlier) date that the "A" category was actually obtained.
So essentially the DVLA are giving us the gift of a lifetime of arguing with insurers over license duration. I think I'll get my pass certificate encased in perspex, I suspect I'll be sending off a lot of copies of it down the years.
KingKong
PostPosted: 14:51 - 06 Dec 2011    Post subject: Re: Licence categories, possible DVLA fuckup? Reply with quote
Then, if 'A2' is showing valid from 23/11/10 on counterpart then insurers have nothing to argue against, as a licence requires evidence in both forms - card and counterpart. Ergo, no year has been lost... Correct?
Kwak 636 (2005)
Past - 2016 Ninja 300 (dark grey); K4 GSXR 600 (sexy yellow); 2002 CBR600FS; 2004 GSXR 1000; 2006 Kwak 636; 2005 Yamaha XVS 1100 Dragstar (facepalm); 2005 Kwak 636; 2011 Yamaha R125.
PostPosted: 16:06 - 06 Dec 2011    Post subject: Re: Licence categories, possible DVLA fuckup? Reply with quote
First, "A2" is a non-existent category, as one tentacle of the DVLA has confirmed.
Second, check out what stinkwheel noted: insurers will take any opportunity to cry foul at the information you've given them - even (and perhaps especially) if they don't provide a way to actually distinguish between A <= 25kW and unrestricted A.
Having 2 dates means there's something to explain, and that's going to be an ongoing headache as we have to use. very. short. words. with. in. shew. rers.
KingKong
PostPosted: 16:10 - 06 Dec 2011    Post subject: Reply with quote
Aha, I get it now...
Point taken and comprehended. Thank you Smile
Kwak 636 (2005)
PostPosted: 00:47 - 07 Dec 2011    Post subject: Reply with quote
After a lot of back-and-forth on the phones today, the woman said "A2 is just something we use internally in the DVLA" and would have nothing more.
I've sent my licence back today (registered post!) with a nice letter explaining exactly what I want and the relevant legislation to back it up. Fingers crossed...
PostPosted: 01:08 - 07 Dec 2011    Post subject: Reply with quote
Great stuff, let's see what they make of it.
Frost
PostPosted: 01:39 - 07 Dec 2011    Post subject: Reply with quote
I passed my test in 2004, the 2 year restricted period ended in 2006, which is what my licence says, cat A licence since 2006. So should that say since 2004 as that's when i actually passed?
PostPosted: 06:30 - 07 Dec 2011    Post subject: Reply with quote
That's what we're trying to get some clarification on.
- You passed your A2 test, granting you an A licence with a 25kW restriction code.
- You wait out the two years, or pass Accelerated Access, and suddenly you've never had a Category A before. However, the DVLA claim you've held an A2 licence, which does not exist.
How the fuck does that make any sense?
The last post was made 14 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 141.05 Kb
